Question about Amana Dehumidifiers
Amana d970 dehumidifier
Not collecting water
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
Illeagle
  • 525 Answers
SOURCE: Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
MNTECH
  • 1543 Answers
SOURCE: not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Posted on Aug 28, 2008
  • 104 Answers
SOURCE: dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Posted on Oct 04, 2008
Does not collect water
Looking at the time of your post I would not expect it to collect much, during the winter things are dry because of the heating. This is a guess as I have no clue as to where you live.
Jan 08, 2014 | Amana D545M Dehumidifier
4-5 years old. Has work great all that time. In the past week it stop collecting water. It runs but never any water in it. It's not leaking out. The collection pail is dry as a bone.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 23, 2011 | Amana D530M Dehumidifier
The dehumidifier runs but does not remove moisture. The coils are cold but no frost. The inner coil is hot.
heatman101
May 17, 2011 | Amana D530M Dehumidifier
+unit will not start.
heatman101
Feb 05, 2011 | Amana D530M Dehumidifier
DOES NOT DRAIN FROM HOSE ONLY BUCKET
heatman101
Apr 15, 2010 | Amana D545M Dehumidifier
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
Dehumidifiers Logo
44 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
