Question about Coby 40 TFTV4028 LCD TV
Screws stand How do I set up the stand
Can't remove tv stand from vizio p50 hdtv20A
You have to unscrew the stand from the set, the screws are on the back. I believe there are a total of 8 screws. You will then have to lift the set off of the stand.
Dec 06, 2012 | Televison & Video
Rca l40fhd1yx9 tv stand
If the set is equipped for a stand Google the model number with the word base or stand and see what you find.
You can also contact Thompson (RCA/GE) to see if available.
Mar 12, 2012 | RCA L40FHD41 40. in HDTV
LG 32FS2ANB keeps going into stand by mode
Recheck your remotes settings most likely it's turned on for stand by sometimes going into your settings and going back to it's default settings helps.
Jan 28, 2012 | LG Televison & Video
NOKIA E52 WLAN SETTING
WLAN stands for Wireless Local Area Network. You should get the internet settings from the service provider as soon as you put in the sim and start your new phone. Anyways here is what you need to do to get the settings.For India... Type PI and sms it to 121. Type MO and sms it to 121. Type WAP and sms it to 121. For each sms you will receive a message saying the settings will be delivered shortly. Just save/install the settings when you receive it. PI stands for Pocket Internet. MO stands for Mobile Office. WAP stands for Wireless Application Protocol. Subscribe all one after the other and save the settings you received. Its Customer Care so, no charges. You may get all setting with just one of the three, I am mentioning all three to make sure you get everything.
Nov 03, 2011 | Nokia E52 Smartphone
Manual that came with camera does not explain symbols for setting the mode. Amazing! What do M, A,S,P, N and SP 1 and SP2 stand for? the only things I understand are Auto and Panorama.
M stands for 'Manual mode'. This is the mode wherein you set your shutter speed and aperture setting. A stands for 'Aperture Priority'. This is the mode where you set the aperture or opening of the lens and the camera sets the shutter speed. The lower the aperture number setting, the more light penetrates the lens, a faster shutter speed is needed. This setting is usually used for portrait scenarios. S stands for 'Shutter priority'. This is the mode where you set the shutter speed and the camera sets the aperture. The higher shutter speed number, the lower aperture number is set by the camera to accommodate more light into the lens. This setting is usually used for capturing moving objects like cars. P stands for 'Program Mode'. The camera takes care of different settings except for the aperture and the shutter speed. You get to choose combinations of aperture and shutter speed settings that will not change the exposure of your scene. This is like a combined 'A' and 'S' mode with different combinations. N stands for 'Natural Light'. The camera tries to make use of available light. This is ideal for indoor use when flash is prohibited or when you just want to capture the ambiance of the scene. The camera sets a high sensitivity setting to handle low light conditions. The drawback of this would be grainier pictures. SP1 and SP2 stand for Scene Position 1 and 2. This is like a memory setting for most commonly used scene settings. For example, you can assign SP1 for landscape mode scene and SP2 for night mode scene. You have 13 scenes to choose from in your camera, 2 of which you can assign in SP1 or SP2. The default setting for SP1 is Portrait mode and for SP2, it is Landscape mode.
Hope this helps.
Apr 15, 2011 | Fuji FinePix S1000FD Digital Camera
How to convert bis 10 desk set to a bis 10 wall set
Western Electric produced 2 different stands for "Classic Merlin" telephone sets. You will need to locate the stand designed for wall mounting. Such stands appear on eBay from time to time. Keep in mind that Classic Merlin telephone sets were discontinued many years ago so locating the correct base might be a bit of a challange.
Apr 11, 2011 | AT&T Merlin BIS 10 Phone
PLEASE GIVE DIMENSIONS FOR LG 47LE5300 T.V.
DIMENSIONS (Width x Height x Depth) in millimeters
SET (w/o stand) (mm) 1127 x 692 x 29.3 Including stand (mm) 1127 x 758 x 285 VESA Dimensions (mm) 200 x 200
Weight in Kilograms
SET (w/o stand kg) 19.6 Including stand (kg) 22.9
Good luck and post back if that helps.
Jan 24, 2011 | Televison & Video
I cannot remove tv stand so that i can mount on wall
There are six screws on the back of the set that remove the stand. Turn the set on its face on a soft surface (bed or carpet). At the base of the TV set (on the TV, not on the stand) you will see nine (9) screw heads. Remove the top three and the bottom three. Leave the middle three in place. The stand just lifts off.
Now, replace the six screws into the TV chassis so if you ever want to replace the stand you'll know where the screws are.
Oct 05, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
My Nokia 3100 swtiches off in stand by condition
Go into your settings/Display settings and activate your power save and sleep mode to on.
Still in Display Settings move to Stand-By Mode Settings/active Stand-By, should be off.
Hope this helps.
Aug 25, 2009 | Nokia 3100
Coby 40 TFTV4028 LCD TV Logo
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
