Home | Philips | 55PP9401 55 in. Rear Projection Television | Replaced Philips 55p...
Philips 55PP9401 55 in. Rear Projection Television
Problem for Philips 55PP9401 55 in. Rear Projection Television
Replaced Philips 55pp9401 convergance and still has issues
By andrewhaerte on May 19, 2009
I have a Philips 55pp9401 and when i had gotten it it had a convergence chip problem. I successfully replaced the chips, ensured that all resisters were fully operational by testing them with a volt meter, and physically placing all wires snug back into place. I still have a slight convergence problem, the left side looks like the green tilts up above the wide screen cut-off, and the right side looks like the blue tilts below it. Also the lettering on my dvd is off with a double right below it. I havent the slightest idea what is wrong with it now, not to meantion that the colors look dull and probably need a cvt fluid change, which i inquired this question and the fluid change kit about at tvrepairkits.com and 2 weeks later still havent gotten back to me. If you got anything for me, something is better than nothing, sorry for the lengthy question.
Comments:
May 19, 2009
- my philips 55pp9401, which is chassis pp15, so it is a hitachi, i just figured since that it had talked about dull colors that it might need a fluid change. But i had gotten my kit from tvrepairkits.com so the chips are stk***110, the exact value that the burned ones were. I understand there is better reliability with 150's and like i said, all resistors have the color rings still visible and still resist.
May 20, 2009
- No, I cannot lie. I just recently moved to Utah from wisconsin and found myself looking at all the good buys that people had on craigslist up here. Half the stuff on the list is simple repairs, so i bought this tv for fifty bucks, spent 60 on a repair kit with all the resistors, heat sink, and new convergence chips for 60 bucks. But you stated that I am better off going through hitachi because the parts i got are probably generic eh?It makes sense but the only other thing with this tv that i don't understand is why the color is so dull and not bright enough to watch movies that are darker set. i have all my settings up to the max and it just makes the black look like ****. So i will try exchanging all the resistors since I've just got them lying around anyways but if you got any other tips for me i really do appreciate it. Thank you
Sep 24, 2009
- one last question, I am finally going to order parts, but I am having a hard time finding a reputable and reasonably priced site to buy the stk394-160 hybrids from. I do not need the entire kit just the ic's so if you could help me one last time it would be great
Solution #1
posted on May 19, 2009
Not Rated)
tech1958
Rank: Guru
Rating: 87%, 48 votes
Acording to my research and if you have the right model number this is an Hitachi chassis in this for some reason Where did you get the ic's from ? If there generic that could be your problem. You always want to buy them from Hitachi and they have a kit that comes with all the resisters . Don't get the cheep ones. Also there is no fluid problem with the Hitachi's. If your looking at the back of the set the IC's should be on the far right side and should have small color coded resisters to the left of them. If any of them don't have a bright color there bad. New IC's should be stk394-160. See if there is a chassis number and let me know.
Comments:
May 19, 2009
- New chips are stk394-160 some resisters are red and and burn to orange. I have had only one problem that was other then normal with these. Like I said almost every 110 ic's I have got have been bad cause the only one's out there are junk unless they came strait from Panasonic or Toshiba. Hitachi part number CZ01341 Have you had this set since it was new ?
May 24, 2009
- Make sure the lenses and mirror are clean
Was this helpful?
Yes
No
Popular Solutions for Philips 55PP9401 55 in. Rear
Questions and Unsolved Problems for Philips 55PP9401 55 in. Rear
Do you recommend Philips 55PP9401 55 in. Rear Projection Television?
Answer
Answer
it took a while to power on now there is no picture or sound
Answer
Hi, I've a Philips Projection TV PTV392, model 52LP50. The problem is that blue ace is down than... (More)
Answer
i have a 55pp9352 and the red went out of wack and its to far out to bring it back with the remot... (More)
Answer
my philips 60PP9202 converge multipoint lines will NOT line up when i try to adjust them!! please... (More)
Answer
my tv turns on then 9 clicks later it turns off,then the process repeats
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 55PP9401 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
