Question about Oki Brand Oki C610dn Laser Printer Network-Ready Duplex Printing
Fatal error 011
Attention light on
How do I get past error code 011
An error code 011 means that the Roku player have lost connection with the server.Try again later to reconnect.Additional help link: am seeing Code 011 error during setup What should do
Jan 08, 2015 | Roku Streaming Stick
What does this mean 010: Fatal Error
010 is not listed in the technical manual for this printer. But 002, 007, 009 and 011 are listed and pertain to the RAM DIMM. For those errors it is suggested to remove the RAM DIMM and restart the printer. If it recovers then replace the RAM DIMM. If it fails again replace the CU pcb.
Jul 29, 2014 | Oki Electric Industry C610dtn Laser...
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
The Attention, Ready, and GO LEDs are on solid
Here is service manual for HP 1160/1320 series ->http://filecom.net/CXW_R.
Solution is on page 34. I hope it will help you.
Feb 27, 2010 | HP LaserJet 1320 Printer
122 fatal error on c5500
Power Supply Fan Motor Error
When low-voltage PSU thermal error or a malfunction of fuser ventilation fan (PX713 only)/PSU cooling fan has been detected. Unplug the printer from the power source, wait one moniute, then plug unit back in and restart.
Seek attention of service person if restarting the printer does not correct the problem
Dec 08, 2009 | OKI C5500n Laser Printer
Changed ink: on and all the lights Attention! box keep flashing
The manual for a related printer suggests that you have a printer failure issue. If the paper lights are off, then it is a scanner failure. If the paper lights are also blinking, then it's a fatal error. Turn off the printer, unplug the unit and then wait one minute. Plug it back in and turn it on, if the lights keep blinking then call HP support. (If it is under warranty, then it may be worth fixing.)
If I misunderstood your post and the power light is steady but the other lights are blinking, then you may have the cover incorrectly positioned or something blocking the ink carriage. Open it up and check for anything out of place.
I hope this helps.
Nov 29, 2009 | HP Deskjet F4100 All-In-One InkJet Printer
My printer
If the printer has three amber lights on, it could be Paper jam light, toner light and attention (triangle) light, then your printer has a fatal error.
Printer definitely needs repair
Issue can be resolve by swapping the formatter board for testing purpose (if you have another model of same printer)
Sep 23, 2008 | HP LaserJet P2015dn Printer
All lights on
Fatal error, I think it has gotten rid of itself, probally fuser at cheapest would be the fix and even that would be more than it is worth to fix. Fatal error will be fuser/laser/board all cost in parts min $100 to 350.
that great but now how do i get rid of it? Place in bin after releasing frustration apon it, if not under warranty
Dec 13, 2007 | HP LaserJet 1022 Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
Oki Brand Oki C610dn Laser Printer Network-Ready Duplex Printing Logo
97 people viewed this question
Top Oki Brand Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Oki Brand Office Equipment and Supply Expert? Answer questions, earn points and help others
