Question about Craftsman 58PC UNIVERSAL MAX AXESS MECHANICS TOOL SET
Adapter won't come out of 3/8 drive - Craftsman 58PC UNIVERSAL MAX AXESS MECHANICS TOOL SET
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Please help me with this
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Nov 03, 2012 | Computers & Internet
Hi there. When talking about USB 3.0. Can say say that there is a USB 3.0 hard drive? Or can I say that if I have an external USB 3.0 hard drive case and place a hard drive in it it would have the USB
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Will not power up
http://www.hitachigst.com/support/index-files/simpledrive-pininfarina-faqs The SimpleDrive and (re)Drive lines require a 12Volts, 1.5Amp or greater, and Center Positive power adapter. So if it's not on warrenty still I would go to radio shack, or somewhere that sells a/c adapters, Take your old one or the drive to match the right size plug. It should work, you maybe able to have them test your adapter to see if its' some other problem, but I've had a/c adapters that show they are making power that won't work the device. Inspect your a/c adapter make sure it's not something simple, like being unplugged, or a cut wire. Hope this helps.
Jun 12, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Netgear wna 3100 won't install on my windows xp. I have uninstalled it 3 times. It won't recognize the adapter. Then it does. Then in the end it won't recognize it even though it's there...
My adapter constantly loses connection completely to the router and cannont be re connected unless i unplug and replug back in the USB port. What a joke!?
May 06, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
Craftsman 58PC UNIVERSAL MAX AXESS MECHANICS TOOL SET Logo
78 people viewed this question
Top Craftsman Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Craftsman Hardware and Accessory Expert? Answer questions, earn points and help others
