Question about Husqvarna Viking 1
Needle won't grab bobbin thread on interlude 435
The bobbin thread doesn't seem to lower into the chamber for the needle to grab it.
sew dutch
  • 25 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 6 Answers
SOURCE: thread breaking with my MegaQuilter,
The problem you describes sounds like it maybe caused by a burr along the thread path. Does the thread shred or does it appear to be cut? Does this only happen with so fine or with other threads as well? Take your finger or if that doeswork use a cotton ball, along the thread path, you are looking for a sharp spot that will be causing your thread to shred. Change you needle for a new one, Make sure you put it in the correct way. Also if these don't do the trick hand wheel the needle up and down a few times. make sure that there isn't a burr in the throat plate from a broken needle and observe near the bobbin case and timing finger that the needle isn't rubbing against something( you might want to use a magnifing glass). i hope this helps. I know how frustrating it can be .
Posted on Jun 24, 2009
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 152 Answers
SOURCE: bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Posted on Oct 06, 2009
  • 30 Answers
SOURCE: I own a husqvarna emerald 116 sewing machine, and
is the bobbin thread in correctly( meaning is the bobbin thread in the lower tension) if it is and the top thread is in correctly and make sure the feeddogs are in the up position if all of these factors are alright then it will have to go to a local dealer to get taken care of
Posted on Oct 28, 2009
Adjust thread and bobbin tension
These are the instructions in the manual:
Adjusting the Thread Tension
Balanced thread tension:
Small amount of the needle thread shows on the wrong side of the fabric.
When the needle thread tension is too tight:
The bobbin thread shows on the right side of the fabric. Reduce the tension by turning the tension dial to a lower number.
When the needle tension is too loose:
The needle thread forms loops and the stitches look shaggy.
Increase the tension by turning the dial to a higher number.
However, if you have recently changed the needle check that it is pushed right up in the slot. Other thing that springs to mind is making sure that the bobbin thread is correctly placed in the bobbin, and that the chamber is not full of lint and threads.
Feb 06, 2015 | Janome Memory Craft 5700
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
The bobbin thread wont come up when lowering the needle
The bottom thread won't come up?
Make sure you:
-Have the top threaded and through the eye of the needle (Basics are best to check, I've missed it once or twice! lol)
-Are holding the tail of the top thread when you lower your needle and pull it back up (Hold it too tight though, and it might not grab)
-Have an inch or two of "tail" or extra thread for the needle to grab on your bobbin thread (sometimes it won't grab if there's not much there)
-Have all your lower pieces in and secure. (Mine tend to jump around if I'm not putting 'em in right)
If it's still not grabbing, I'm not sure. Sorry, hope it helps.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
The needle will not grab the bobbin thread
Double check the needle position when you put your new needle in. It is so easy to put them in backwards or sideways when learning a new machine. Also try checking the thread path of the thread, that it is not wrapped funny.
Jul 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
15 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
