Question about Epson Stylus C44UX InkJet Printer
Red light not goin off
The red light at the top of printer is not goin off and the printer just sits there not doin nothin iv changed the ink but still nothin
  • 1 more comment
  • GregBt Jan 06, 2008
    Same problem, hp photosmart 7660 . plug it in, turn it on, at first the "on" switch light goes green, but after a moment it blinks red and won't work and won't turn off. Don't know what's wrong. If I unplug it and then plug it back it, it does the same thing time after time.Took paper out, put paper back in, checked the ink reservoirs. I've had it for a year or two I think. I'd think it would last longer, I definitely consider hp quality is getting WORSE!
  • Anonymous Mar 05, 2008
    same as above
  • slayerwba1 Sep 26, 2008
    red light light won't go off and won't work
    Problem Solver:
  • 5 Answers
What model is ur printer?
Posted on Oct 19, 2007
Hi I have just put in ink cartridges and the reg light check print cartridges keeps flashing is there anyone there to help me
Hello and Welcome to FixYa!
Sir/Ma'am If the Check Print Cartridge message is shown and Red Light Flashing then it means that Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. For it Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press push mark until ink cartridge click into the place.
If you are sure then you have installed ink cartridge properly then try following to stop the flashing of red Light.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
Now Turn On the printer, Mostly this issue is resolved by this,
But if still you get the message and red light still flash then surely its an issue of Ink Cartridge, your ink Cartridge is defective, You need to change the ink cartridge, Your problem will be solved.
I hope this solution helps you.Don't hesitate to let me know if you still have some confusion in your mind.
Please Rate my solution as "Maximum Stars" and then give your Words of Appreciation as a Feedback.
Thank you Sir/Ma'am for taking my service and fir using FixYa
Concerned: Muhammad Uzair Team : FixYa
Nov 05, 2011 | HP DeskJet 920c InkJet Printer
I have had this problems before and I don't remember what I did to fix it. I have checked the default paper type and worked with the margins to no avail. The footer is also cut off in print preview. Any...
my printer was epson dx7400
iv loadednew inks genuineinks cheta putpoweron printer load ok but was flashing light
look ikns mt iv try inks no t012 t013 t014 t011 that was £45.00
stillnot working
try compatibe inks the same nothe same was still not working
im sorry iv had astroke as myproblem is worying my head
thanks fire16
Jan 11, 2011 | HP Office Equipment & Supplies
I have this xternal drive and its resently started goin solid red
I would try using the software called spinrite 6
http://www.grc.com/sr/spinrite.htm
Apr 23, 2010 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Red light on printer
your printer's cartridge is not fixed correctly and top cover may not closed correctly.
Jul 11, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Handset just blinking red light
You need to connect the phone to your pc without the battery install and open up your blackberry desktop manager.....go to application loader and update the phone's OS , this should correct the problem :)
if it does not work let me know but this method have not failed me yet nor my customers/
Mar 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
My primera sig IV interior red lights stay on...
The interior light is part of the cartridge optical reader assembly and tells you that it isn't recognising the ink cartridge. Either they are the wrong cartridges or the bar code at the bottom of the cartridge is unreadable. Using a cotton bud dipped in a bit of metho wipe around the red and clear led's ensuring you clean the small slot next to the led's (the reader). Also either clean the barcodes on the cartridge, or change the cartridges.
Dec 04, 2008 | MicroBoards Primera Signature IV InkJet...
Ink is out eventhough there is ink in there!
Usually printer companies do not support refilled cart , as in this the problems lies with cart ,change to original cart or replace the defective cart .
May 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R-260 Printer
Which Led light is Red ? Ink Button? Open the printer cover then press and release the ink button, printhead will move to the center in which there is an ink out indicator pointing to one of the ink, press and release the ink button several time to determine what other ink/color are out. replace inks and try printing after getting a solid green light on power button...
Mar 11, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus C44UX InkJet Printer Logo
62 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
