Question about IOGear GUWAVKIT4 Wireless 1080p Computer to HD Display Kit w/HD
Guwavkit 4 does not work wth win 8.1
Running the program actually causesthe computer to crash.
I loaded flight simulator 2004 on my new computer with windows 8.1. It loaded fine. After when I clicked on the flight simulator icon, the program will not run.
if you ck the box the game came in you will see that its only 4 win2k and maybe win-xp depending on the time you bought it , it wont run in a windows version that was created long after it was written , now that being said , win 2kpro version does have a backwards compatibility version , but then the other newer software you have loaded will not run stable and is prone to crash"s (blue screen of death)
a possible solution to your problem is something like I've done ,I've taken a old laptop with win xp running on it ,and islanded it (never connects to internet or network) so that m-soft cant ever shut it off this one I load all my great ole games to it (flight sim, trainz ,etc.) and it works just fine
Sep 28, 2015 | Microsoft Flight Simulator 2004
Nitro pro 8 software crashes problem
WHEN does it crash? need to the know the circumstance to help. But you could try running a repair on the software from control panel/add-remove programs,
Aug 29, 2014 | Computers & Internet
Software plays but shows no picture
Late, but the answer that works for me.
Run Compatibility Mode win 95 or win 98/ME.
Edit the shortcut. Edit the Target.
Add -window after the existing text in Target.
e.g.
"C:\Program Files (x86)\Hasbro Interactive\Super Scattergories\Scattergories.exe" -window
Apr 16, 2013 | Hasbro Interactive Super Scattergories for...
Google chrome is loaded in windows 8 but is running in desktop ,which means i cant use java or other etc
as of what I understood from what you have written(I didn't understand most) you want to run two instances of Chrome in the "Modern style Windows 8" and the Desktop, sadly it's impossible as to many crashes and bugs with it = http://www.youtube.com/watch?feature=player_detailpage&v=Rfh5Ioih0Is
Just an example.
So, can you please answer these questions (don't type fast, write it clear and short), so that I can finally understand your problem:
1. Is Java installed on your PC?
2. You are using Windows 8, right?
3. Your primary browser is Chrome, yes?
4. IE10 "Modern" can't run Java or Flash?
5. Does the Desktop IE run Java and/or Flash?
If you have more details = just add them at the bottom.
Mar 25, 2013 | Computers & Internet
I want to start safe mode on inpriron 11420
From what i see in your specs the Dell Inspiron 1420 came with Win Vista. I assume you have upgraded, Did you check Win 8 compatibility with your hardware? You may have exceeded the hardware components limitations. Therefore it will not run Win 8 with much sucess, and will continue to crash, Check here: http://windows.microsoft.com/en-US/windows-8/system-requirements. That said, I would use win 7 at the most.
Dec 26, 2012 | Dell Inspiron 1420 Notebook
I had the microsoft picture it 7.0 program for years. my computer crashed and i can't find the program. i love the program. can you please help me
You really need to give more details 'what operating system is it ie; win xp , vista or win 7 and what happened after the crash was the computer repaired or restored or was it reformatted etc? one thing to try is to just do a basic search using the windows file search program --go to start - search for files- type in the file name and click search or use advanced search and search for all files with the specific key words of the program IE:picture it 7.0 or Microsoft picture it -- hopefully it will bring up all the files related to what you are looking for -if it does then look for the actual application files and find the directory it is located in ---example -- c/windows - system 32- etc you should be able to start the file from the actual file folder and then create a desktop short cut to it .some times after a crash shortcuts are lost while the actual program is still installed.
I hope this helps
Andrew
Mar 26, 2011 | Microsoft Computers & Internet
GV-650 12CH PROBLEM
Update your drivers to run on the new OS
if the drivers are unavailable try running the program in Compatibility Mode
Right click on the icon on your desktop or from 'All Programs' - select 'Properties'
Select the Compatibility tab
Select Compatibility Mode
Use the dropbox to show the OS
Click OK
Restart your computer
Jun 03, 2010 | Geovision GV-650 8 Channel Video Capture...
May windows can not open google erth?
1. Goto Start, computer
2. double click on the "C" drive
3. Open the "Program Files (x86)" folder)
4. Open Google
5. Open Google Earth folder
6. Open client folder
7. Look for "googleearth" that is the application, not the icon.
8. Right click and create a shortcut.
9. agree to have it placed on your desktop.
10. Try icon on desktop and have fun.
Jun 01, 2010 | 3M Saws
I received a bluescreen with message turn off
It sounds like you have a virus.
try and start the computer in Safe Mode just hit your reset button and then Press F5 before windoze starts.
select "Start Safe Mode with Networking"
Update your antivirus program and Try to run another antivirus scan.
If that doesnt work, you need to do this........When Windows crashes, it writes a system event 1001 and a minidump to the folder\
\windows\minidump Check system event 1001 and it has the content of the blue screen
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001.
Copy the content and email it to me at clb199@yahoo.com
pls rate 4 stars
short of that, you are going to have to
Dec 01, 2009 | HP Computers & Internet
How to upgrade win 95 to winxp without removing files installed
A computer running Windows 95 WILL NOT RUN Windows XP in most cases. Post all of your hardware details and we can explore that further.
Most programs that run on Windows 95 WILL NOT RUN under Windows XP easily. There are some compatibility things you can try for each one, but most simply will crash, and some will seem to work for a while then crash at inopportune moments.
What you should do is buy an newer computer with Windows XP, remove your current hard drive, and put your current hard drive as a second drive in the new computer. You will have access to your documents, but your programs will not run.
Mar 14, 2009 | Intel Pentium III, 800 MHz...
IOGear GUWAVKIT4 Wireless 1080p Computer to HD Display Kit w/HD Logo
109 people viewed this question
Top IOGear Televison & Video Experts
Electro Med Services...
Are you an IOGear Televison and Video Expert? Answer questions, earn points and help others
