Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
Bissel little green machine model 1400 doesnt spray
reddevil6
  • 1673 Answers
SOURCE: Bissell 1720-1 Little Green
If it isn't spraying, the pump is most likely bad, leaking from tank, depending where it is leaking, may need a new tank. But Bissell has obsoleted this unit and its parts. So unless you can find the parts somewhere, it may be time for a new one.
Posted on Feb 29, 2008
SOURCE: will not spray
I have had to take mine apart every time I use it. The passages in the heater get clogged with cooked soap residue and this keeps the fluid from flowing properly. The crystalized soap has also plugged the tube in the handle, and the attachments, quite a few times. I am now having trouble with water leaking out the bottom when running the cleaner. I have traced this back to the heater. It seems that the soap, or something, has eaten a couple of holes in the removable metal cove that seals the back of the heater. This is the same cover that I have had to remove quite a few times to clean the passages out. I have fixed this temporarily, but now I need to order a heater assembly, as this piece is not sold separately. I like the machine and the way it cleans, but it sure has its share of problems. Hope this helps somebody. One way I found to slow down the heater plugging up, although it still does it eventually, is to make sure I have fluid coming out the attachment before turning the heater on. It seems to cook whats in the heater less.
Posted on Aug 29, 2008
  • 389 Answers
SOURCE: How do you operate the Bissell 1725 LittleGreen Machine Proheat
Go to www.bissell.com then click the Customer Service tab. In the next window click on the User Guides link (in green on left hand side), then enter your model number. You can then download the full instructions.
Posted on Mar 15, 2009
SOURCE: my little green machine won't spray the solution but it will pick
We had the same problem. After dissassembling the whole machine we could not find a clog or any other obvious problem. The manual suggests priming the pump by putting the solution reservoir in and out a few times. This did not help much. What did work was to raise the unit up a few feet above the trigger while depressing the holding the spray trigger. (That is, use gravity to fill the tube.) After solution was flowing freely, we turned the machine on and it seems to spray fine again.
Hope this helps
Posted on Jul 22, 2009
CRTN
  • 716 Answers
SOURCE: bissell little green machine will not spray
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
Posted on Jul 29, 2010
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Bissell little green instruction manual
    Hi, it's Jeremy from Crucial Vacuum.
    Attached is a copy of the user's manual for your Bissell 1400 Little Green Pro Canister Steam Vacuum:
    http://www.bissell.com/assets/0/132/134/228/83bcc4e8-41c1-4b5f-8547-17c9af450a80.pdf
    You can purchase direct your Bissell replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    http://www.crucialvacuum.com/bissell.html
    I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
    Jeremy Lerner
    Crucial Vacuum Customer Care
    Aug 04, 2014 | Bissell 1400 Little Green Pro Canister...
    Bissell 1400-5 trigger stuck and not spraying
    Hi there. Not having spray when you really need it can be frustrating. I'm sorry you're having difficulty with the trigger.
    You may want to have a Qualified Tech at one of our Authorized Service Centers inspect your machine. Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
    Aug 04, 2013 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    I need the switch in the handel on the little green machine model 1400 J04336 When I put this in they say it can't be found
    If you go to this URL:
    http://www.vacpartswarehouse.com/Bissell-Little-Green-Models-1400-2-1400-5-1400-H-1400-U-s/591.htm
    you will see an exploded view of your unit and see the switch and associated part number.
    If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you! Paul
    Oct 07, 2010 | Bissell Vacuums
    Little green machine will not spray. Can I fix it?
    yes according to the model you have look up a schematic on line and take it apart you will see the pump assy the pump # is 6035029 this can be purchased on line i got mine at VacParts Warehouse.com think it was about 14 or 15$
    Sep 11, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Need instructions on how to fill and operate a new machine. (Bissell Little Green)
    BISSELL User's Guides can be downloaded at www.bissell.com
    On the front page under Customer Service click on User's Guides and enter the model number of your unit.
    User Guide will be displayed as a PDF file.
    Mar 18, 2010 | Bissell 1400 Little Green Pro Canister...
    Clean solution leaking out the bottom
    open it up again and check the pump there is probably a hose leaking ,did you put the clamps back on the hoses
    Apr 14, 2009 | Bissell 1400 Little Green Pro Canister...
    Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
    96 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
