Question about IBM Office Equipment & Supplies
How to remove the cover from an IBM selectric.
IBM selectric , how to get the cover off?
  • ddfrance May 20, 2009
    Thank you DickyO.Case came off easily.
  • IBM Master
  • 3,594 Answers
First remove the platen. There is a lever at each end of the platen push them down and remove the platen.
Then inside the case on both sides are levers, pull them towards you and remove the case. The levers are inside the case right against it.
DickyO
Posted on May 19, 2009
How to unlock typewriter?
Remove cover and in the back there is the motor and belt, with machine off, try turning the belt. There is a tool that screws into the main cam shaft that allows you to turn the main cam shaft. most likely something is stuck. These IBM Selectric need oiling on a regular schedule.
Aug 15, 2017 | IBM Office Equipment & Supplies
Anyone got a possible answer for why my IBM correcting Selectric II won't come on?
If you know how to remove the upper cover there are a few things you can check. turn it on if the motor is trying to turn it may be gummy motor bearings lube them If it dosen't try the off on switch may be gummy. almost anything you will need a tech.
DickyO
Oct 08, 2014 | IBM Correcting Selectric II
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
How do I remove the ball from an ibm selectric typewriter?
At the top of the Selectric ball there is or should be a rectangle in the plastic. This is a lever. Bend the lever until it is standing at 90 degrees to the original position. Give a tug on the lever. The ball should lift right out.
Oct 01, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II problem
Yes, I did bring a small screwdriver from home and removed the ball. Thank you for your assistance.
Feb 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
528 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
