Question about Craftsman 24 Hp 48" Deck Yard Tractor
Have a 23hp craftsman garden tractor with kohler engine no wiring
The engine has the wiring harnest connector, the starter is hooked up to the battery, a red wire from pos on bat is going to amp meter then to non factory ignition switch, the switch has bat, light, mag, gnd, selonoid connectors, there is also a hevy duty toggle for the electric clutch , two prongs, and there is two wires off the clutch pulley for mower belt. no safety switches. the biggest issue is what do i hook up to the engine connector there is six slots, 3 in each row ,white-blank-orange next row blue, black, red which jumps back to blue the engine side has blue off sylenoid, the three rows blank-white-orange/purple next row blue/red-green-orange/red
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,025 Answers
On most starter switches the back of the switch is labeled which wire goes to what
Posted on Jan 21, 2018
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
  • 104 Answers
SOURCE: Murray Lawn Tractor Model 42576x92A will not spark?
I found a wiring diagram that I hope helps you out.
Posted on Jul 29, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
  • 9 Answers
SOURCE: Engine dies when I engage the electric clutch for my mower
Possible short to ground in the clutch wiring
Posted on Oct 22, 2009
  • 2478 Answers
SOURCE: My dog tore out some wires on lt1000 17.5 hp ridng
Orange wire goes on the A2 terminal on back ignition witch.
Posted on Mar 01, 2012
How do I fix burned wires on Craftsman LT 2000 w/17hp Kohler burned wires. Need wire color diagram.
get the manual, it has a wiring diagram. You will probably be able to buy a new wire harness as well.
Aug 30, 2014 | Craftsman Garden
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in
Dec 02, 2012 | Garden
I have a craftsman kohler magum 18 hp twin runs fine until u release clutch then it dies why?
I had the same problem with my tractor.same tractor and everything.all u have to do is you know the wires that hook up to your seat?them 2 wires cant be touching eachother.if them 2 wires that hook to your seat r touching eachother,it will stall out when u let out the clutch.
May 01, 2011 | Craftsman Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can I add an hour meter to my Crafstman 917.289340 lawn tractor with the 22 HP Kohler engine? Found a part #401763 for a different model Craftsman. Will it work?
Yes, you need to find a wire that is hot (12vdc) when the engine is running, tap into this wire and hook to the positive side of the hour meter and the other will be a ground. This will keep track of engine hours only. If you want complete total hours, any hot wire with the switch on will work.
Feb 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riging mower will not charge. Son hooked cables up wrong and most likely blew the diode. Where is the diode located?
if it is a briggs engine it is in the wiring harness coming off the alternator, where it plugs into the main harness coming out of the dash area. it will appear as a lump in the wire [sometimes there will be two diodes]. if it is a kohler, it will be in the wiring harness under the shroud covereing the flywheel
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
300 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
