Question about Cybergun GSG 522 AEG Airsoft Gun by ICS, Retractable Stock
Won't shoot I fully load the magazine. Battery fully charged, gun fires but nothing comes out
Why does nail gun not fire? Safety works ok. Gun loaded with 2 1/2" finish nails. Trigger safety switch is off. Slight hiss of air when trigger depressed but does not fire.
Hi Charles & Floyd:
Just a couple of thoughts that may assist.
First. This is an air tool so it is DANGEROUS! Treat it like a LOADED GUN.
Here's what I would do:
- Disconnect from air supply - point away from anything I don't want to hurt, and squeeze trigger. Press safety against block of wood and squeeze trigger.
- Now that I know it is safe, I would remove the nails from the magazine and check that none is stuck in breech mechanism.
- Check that feed spring/latch has released. Sometimes if loaded too full it can catch.
- Load some nails, check that they are the correct fit, and are sliding in the magazine.
- check air supply pressure. Should be between 80 and 100 psi.
- reconnect air supply and try again.
- If it does not fire it may be that the piston is not fully retracting. Since it is new, I would be returning it to the store where it was purchased.
Hope this helps.
Apr 18, 2016 | Porter Cable-Cable FN250C 1-inch...
I've got a hitachi 2nd fix nail gun and for some
First thing is , when did You clean it last?
Sep 30, 2014 | Tools & Hardware - Others
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
Black and decker 1802 nail gun will not fire with a fully charged battery
The battery may be falsely indicating it is completely charged when, in fact, it should be replaced
Mar 05, 2014 | Black & Decker Black Decker Firestorm...
The BBs won't come.the gun won't it's a MCSR01 crosman air gun
With magazine out, what happens after cocking, should get a gush of air, if nothing, spring not latching, or seal leaking badly, have you adjusted trigger, to fine with a spring type, will not latch, so no pressure, can you feel anything happening, nothing at all spring latch, can you feel the pressure of the spring when you cook it.
Mar 15, 2013 | Optics
There is no light coming on with a battery connected
First what kind of gun? If Paslode- may need new gas cartridge. And is power light green (still paslode gun.) If other type of gun can't help. sorry.
Feb 17, 2013 | Air Tools & Compressors
Brand new gun seems to be in good working order,
If nothing is jammed the the hammer that hits it is probably not hitting could be bent,you can try cleaning and putting about 1/2 load in it .if not shouting then it isn't in good order / if new way not return should be warranty/defect
Mar 20, 2010 | Air Tools & Compressors
Shoot no shoot
make sure that the filter in the back is clean you can pop the back cover off and clean it with water if it is dirty then the excess co2 gas that the gun gives off will not be able to excape the chamber and sensors inside the gun will not let if fire. This should work for you
Sep 01, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Framing nailer intermittently doesn't shoot the nail.
Make sure to blow out the magazine where the nails load, make sure the spring tension on the nail clip is working properly, make sure you're not holding the clip somehow with your off hand so the clip can't feed correctly.
Apr 20, 2009 | Tools & Hardware - Others
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Cybergun GSG 522 AEG Airsoft Gun by ICS, Retractable Stock Logo
77 people viewed this question
Top Cybergun Sport & Outdoor - Others Experts
Are you a Cybergun Sport and Outdoor - Other Expert? Answer questions, earn points and help others
