Question about Ricoh Aficio 1035 Copier
How to Stop the Counter
Kindly tell me how to stop the counter
because on every print it count the copies
so i want to stop the counting
so, kindly help me
  • Chris
    Chris May 11, 2010
    Is the printer owned or leased?
  • 95 Answers
You can't stop or reset the counter.
Posted on May 20, 2009
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
Minolta EP 4000 error M2 how to solve this problem?
Sir, Need to dump the waste toner box and clear the waste toner box counter in service mode. Stop 0 stop 1. select Counter clear Waste toner count count should be set to 180,000 copies for overseas
Panel reset for exit service mode
Apr 24, 2016 | Minolta Office Equipment & Supplies
My Canon Pixma MP130 tells me my Waste Ink Absorber is nearly full. Manual tells me not to touch but how do I replace or empty?
This is a safety function that Canon ans Epson built into theyr machines. Normaly this problem can be solved by replacing the absorber pads (or cleaning them) however you will need a service mode tool to reset the ink count in the eprom. Search google for the specific tool for your printer.
Good Luck
Dec 09, 2010 | Office Equipment & Supplies
Pixma mp 130 Message waste tank absorber is almost full. It wont print
Take the printer to a qualified printer technician.
He/she will empty the waste-container,
and "reset" the electronics inside the printer,
to tell the printer that the waste-ink container has been emptied.
Oct 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Where do you find the counter on your Copystar system?
Depress the [Stop/Clear] key for 3 seconds. The Copy Count will be displayed on the No. of Copies display.
Pressing on the [Start] key while the Copy Count is
displayed will output the Counter Report.
Oct 19, 2009 | Kyocera Copystar CS-1620 Black and White...
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink absorber is almost full will not print
wait until the absorber counter full and reset it with this instructions
Mar 25, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Item counter
there are several positions on the print item button. All of the way to the right the counter is on. To stop counting move one mor position to the left.
Sep 09, 2008 | Canon MP-25DV Calculator
Ricoh Aficio 1035 Copier Logo
205 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
