Question about Husqvarna Sewing Machines
Threading a bobbin diagram - Husqvarna Sewing Machines
2 Suggested Answers
  • 1788 Answers
SOURCE: Kenmore 100 stitch 385 Bobbin thread does not
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
Posted on Sep 11, 2010
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
Tried to thread the bobbin but the machine just have the sound but not doing anything
are you sure you followed all steps? Make sure you followed the
threading diagram correctly. You must pull your thread through a hole in the bobbin,threading from the inside of the bobbin to the out side .hold the thread on the outside of the bobbin and wrap thread around the bobbin shank twice. Hold the thread in place and find the groove on the bobbins' outside then match that to the "wire" on the spindle of the winder. You will then disconnect the drive by turning the small knob inside the hand wheel. Next ,you will push the bobbin spindle against the small wheel to create traction to turn and fill the bobbin. My guess is that either the bobbin was not in place or you forgot to push the winder against the traction area. Happy sewing.
May 14, 2014 | White Sewing 1409 Mechanical Sewing...
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
Need to know how to thread and use bobbin in Elna 210 sewing machine
I can't see this manual available at the usual spots of:
www.sewingpartsonline.com
www.sewusa.com or
www.diplodocs.com
but you could email either of the first two websites and ask them.
If you look at the threading up diagram here,
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
it may be sufficient info to get your machine running.
I'm presuming it is a front loading bobbin and case model? Many models are this style Singer, Jones/Brother, Toyota, Bernina, once you've mastered the bobbin case and bobbin, they are all very similar.
If it is a top loading bobbin style then look at the threading up diagrams for the Janomes, it may be more like them. These there is no removable case, you load the bobbin into the bobbin holder and click the thread into the tension spring.
The critical thing for threading up all sewing machines, is winding the bobbin nice and smoothly, getting it into the bobbin holder or case the right way and placing the thread tail into the tension spring correctly so the thread is under tension as it feeds out.
And for the top thread, it must go through the take up lever, tension dial (usually two metal discs that press together with a spring) and then down through the needle eye.
Always, thread up the top thread with the pressure foot up - this opens up the tension device.
Hope this helps out a little at least.
Sep 20, 2011 | Sewing Machines
I need a manual for an Elna Special machine. I am not sure of how to thread the machine properly and I don't know what one of the dials on the front of the machine does.
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
Feb 24, 2011 | Elna Sewing Machines
Kenmore 100 stitch 385 Bobbin thread does not engage into stitch, Needle goes down but thread does not pull up into stitch. Threading bobbin according to diagram on foldout section. replaced the bobbin...
Sep 10, 2010 | Kenmore Sewing Machines
Loading a sewing macheine
There are two threads you're asking about, or could possibly be asking about. The first is the top thread. There is a diagram across the top of the machine with numbers(1, 2, 3, etc) detailing where to put the thread and how.
Your bottom thread, otherwise known as your Bobbin, will have the same diagrams, depending on whether it is a top loader, or a front loader. If it is a top loader, simply remove the bobbin door, and drop in the bobbin, making sure the thread is facing the direction the diagram tells you it should be facing. For a front loader, the diagram will also ensure you know what you're doing, often with a bobbin case involved.
Apr 23, 2010 | Brother LS-2125 Mechanical Sewing Machine
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Elna supermatic bobbin and threading instructions
Check out these instructions and diagram. Good luck. Paste this link to your Address bar... http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Sep 09, 2007 | Sewing Machines
Threading machine
The machine is relatively simple to thread. This is what I do and I've had no threading problems. 1. Put thread spool on the spool pin and put spool guard over spool pin to hold spool onto pin. 2. Take thread and put it under the bent tab by the circle tensioner. bring the thread around the right side of the circle tensioner and bring around the front of the circle tensioner thing back to the top hook on the far left side of the machine. 3. Take the thread around the backside of the top hook think until it threads through the flat piece on the left side of it. 4. Bring the thread down through the first (right side) channel and under the plastic piece to the second (left side) channel. 5. Bring the thread up the second channel and around the moving thread holder and past it's flat metal piece to hold it. 6. Tuck the thread around the small wire thread holder below the needle screw. This may take a few passes to catch it. 7. Thread the needle from the front and run the thread between the teeth of the presser foot. 8. Put a bobbin in the bobbin case so that the thread pulls off the bobbin from the left side of the bobbin if you look at it from above. 9. There is a small channel in the bobbin case that is covered by the bobbin tension flat piece. Pull the bobbin thread through this channel and into the empty space where the needle thread will catch. 10. Place the bobbin case into the machine with the little set bobbin arm pointed to the sky so that it fits into the machine without wiggling to the right or the left. 11. Turn the, uhhh brain fart, the hand wheel until the needle comes back up with the bobbin thread hooked over the needle thread. Take a narrow thing, like scissors or a seam ripper and pull both threads until the bobbin thread comes up. Now your machine is threaded. Use these directions with the pictures in the book to get this machine threaded.
Dec 11, 2006 | Euro-Pro Fast and Easy 420 Mechanical...
Sewing Machines Logo
13 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
