LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
The possibilities are -some one might have changed it for you. If someone got your password or hacked it then they could get on your network and change the password on the wireless router. Or did the router get reset without your knowledge(has the non-guest access changed)? If you left the default log in to the router you might want to change it also, it makes it harder even if someone gets wifi access.
connect pc to modem with ethernet cable. open web browser and in the address bar type 192.168.1.1 this should bring you to the home page of the modem. for user and password type admin if this does not work try admin and password. then go through settings and change password and save.
This happened to me last night. I took my streamer to a friends house, but when i came back it was recognizing my SSID but not accepting my password. I don't know exactly what happened but i tried unhiding my SSID and redoing my password, but it still wouldn't work. ultimately I renamed my SSID, Password, and PSK. Then on my streamer I found my router through WPS. I just added the router PIN and it connected and brought everything up. Re- entered my password and was good to go.
If you are talking about the password to log in and make changes to router settings, according to the user manual for this router, found HERE, the default password is no password, in other words, leave it blank. If that doesn't work that means someone put a password on it and you will need to reset the router in order to log back in and make changes.
If you need help with that, refer to the manual, or reply back to this message and I will help walk you through it.
did u chek the wireless router,chek it and if every thing is okay. then chek if the is any tall trees in front of the router lokation, because i play fear combat and i had the same problem, there so tall trees in front of my house. if there i isnt i suggest u call the enternet company
