Question about Microsoft Office Project Standard 2007: Windows
I want alpha numeric in msaccess with primary key front end of vb
My save source code is given below
Private Sub cmd_save_Click()
'error cheaking and autocorrection handle
On Error GoTo errlable
If (cheak = True) Then
If (txt_note.Text = "") Then
txt_note.Text = "None"
End If
If (txt_phone.Text = "") Then
txt_phone.Text = "None"
End If
If (txt_mail.Text = "") Then
txt_mail.Text = "None"
End If
If (saveflag = True) Then
txt_bookhnd.Text = 0
str = "INSERT INTO Member "
str = str & "(Address, Birthdate, Bookinhand, Deposite, Doexpire, Dojoin, Email, Fname, Lname, Memid, Noted, Phone, ***) "
str = str & "VALUES('" & Trim(txt_add.Text) & "', "
str = str & "'" & Trim(msk_bdate.Text) & "', "
str = str & CDbl(txt_bookhnd.Text) & ", "
str = str & CDbl(Trim(txt_deposite.Text)) & ", "
str = str & "'" & Trim(msk_expr.Text) & "', "
str = str & "'" & Trim(msk_join.Text) & "', "
str = str & "'" & Trim(txt_mail.Text) & "', "
str = str & "'" & Trim(txt_fname.Text) & "', "
str = str & "'" & Trim(txt_lname.Text) & "', "
str = str & CDbl(Trim(txt_memid.Text)) & ", "
str = str & "'" & Trim(txt_note.Text) & "', "
str = str & "'" & Trim(txt_phone.Text) & "', "
str = str & "'" & Trim(cmb_sex.Text) & "' )"
'MsgBox str
Memconnection.Execute str
Else
str = "UPDATE Member SET "
str = str & " Address = '" & Trim(txt_add.Text) & "',"
str = str & " Birthdate = '" & Trim(msk_bdate.Text) & "',"
str = str & " Bookinhand = '" & Trim(txt_bookhnd.Text) & "',"
str = str & " Deposite = " & CDbl(txt_deposite.Text) & ","
str = str & " Doexpire = '" & Trim(msk_expr.Text) & "',"
str = str & " Dojoin = '" & Trim(msk_join.Text) & "',"
str = str & " Email = '" & Trim(txt_mail.Text) & "',"
str = str & " Fname = '" & Trim(txt_fname.Text) & "',"
str = str & " Lname = '" & Trim(txt_lname.Text) & "',"
str = str & " Memid = " & CDbl(txt_memid.Text) & ","
str = str & " Noted = '" & Trim(txt_note.Text) & "',"
str = str & " Phone = '" & Trim(txt_phone.Text) & "',"
str = str & " *** = '" & Trim(cmb_sex.Text) & "'"
str = str & " WHERE Memid= " & CDbl(txt_memid.Text)
'MsgBox str
End If
Memrecordset.Requery
Memrecordset.MoveFirst
MsgBox ("Record saved successfully."), vbInformation, "Save"
Call locktext(True)
Call setbutton(True)
Call showdata
End If
Exit Sub
errlable:
If (Err.Number = -2147467259) Then
MsgBox ("Member ID already exist,please enter anothe ID."), vbCritical, "MemberID exist"
txt_memid.SetFocus
ElseIf (Err.Number = -2147217913) Then
MsgBox ("May be date field pattern wrong."), vbCritical, "Date"
ElseIf Err.Number <> 0 Then
MsgBox Err.Number & Err.Description
End If
End Sub
how to change numeric as alpha numeric in ms access with vb
  • ethenmozhi May 27, 2009
    Thank U sir, Thank u somach
  • 78 Answers
CStr(variableName) where variableName contains the number
Posted on May 21, 2009
I have a problem about the code for vb 0.6 the code for progressbar
i put the timmer also to look nice add this code :
Private Sub Timer1_Timer()
If ProgressBar1.Value = 100 Then
Timer1.Enabled = False
Else
ProgressBar1.Value = Val(ProgressBar1.Value) + Val(1)
End If
End Sub
If u Want A Button Disable The Timer add a Button with the Code Timer1.Enabled = True
Feb 19, 2010 | Computers & Internet
Tip
How to Open a Password Protected Word 2003 Document?
Microsoft Word document offer password protection which allows you to protect your sensitive information containing in your Word file, then anyone who wish to access to your file should enter the correct alpha-numeric password firstly. If you cannot open a secured word 2003 document, it must be irritating, right? This article will show you three effective options to <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"><u>open a password protected word 2003 document</u></a>.<br /> <br /> <img src="open-password-protected-word-document.jpg" /><br /> <b><br /> <br /> Method 1: Using VB.NET<br /> </b><br /> <br /> The following code sample shows how to open a password protected word document using VB.NET<br /> <br /> [VB.NET CODE STARTS]<br /> Dim objWord As Object<br /> Dim strPassword as string = "PASSWORD"<br /> <br /> objWord = CreateObject("Word.Application")<br /> objWord.visible = False<br /> objWord.application.WindowState = 2<br /> objWord.application.DisplayAlerts = False<br /> <br /> Try<br /> objWord.Documents.Open("YOUR DOCUMENT FULL PATH NAME", PasswordDocument:=strPassword )<br /> Catch ex As Exception<br /> Msgbox ("Cannot open word document" ,vbExclamation , "Password Protected")<br /> End Try<br /> [VB.NET CODE ENDS]<br /> <br /> <br /> <b>Method 2: Obtain the password from the source</b><br /> <br /> <br /> The following steps sample shows how to obtain the password from the source<br /> Step 1: Check with the word document source for the password.<br /> Ask yourself where does the locked word 2003 document come from? Supposing it created by someone else, then ask the creator for the password. If your own are the word document source, you will need to locate the lost password.<br /> Step 2: Verify the password with the source.<br /> Make sure you have the right password on hand. Verify the password can save you time. The other reason to do so is that you never know they might have given you the wrong password in the first place.<br /> Step 3: Enter the correct password.<br /> Type in the correct password at the "Enter Password To Open File" dialog box. After you have entered the password, click the OK button.<br /> <br /> <b><br /> Method 3: Using password-cracking software</b><br /> <br /> <br /> If so far you still didn't solve your problem, then you'll have to go buy one of password-cracking software available for this purpose. So go to the link in "Source(s)" and download the <a href="http://www.recoverlostpassword.com/products/wordpasswordrecovery.html">word password cracker</a> program. It comes with a trial version and follows the walk through. You only need to use the program to open the locked word document, choose the type of attacks for word document with strong encryption. Then the program will start and keep running until find out the lost word password for you to open.<br /> Source(s):Good Search: <a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html">SmartKey Word Password Recovery<br /> </a><br /> <br /> Keep in mind that there nothing will miss as long as you use the corresponding password to<a href="http://recoverlostpassword.com/products/wordpasswordrecovery.html"> <u>open your password protected word document</u></a>. <br /> <br /> Article Source:<a href="http://recoverlostpassword.com/article/open-password-protected-word-2003-document.html">http://www.recoverlostpassword.com/article/open-password-protected-word-2003-document.html</a> <br />
on Apr 15, 2011 | Computers & Internet
Program code that can light a bulb using vb
You can do it a couple of ways, but this would probably be the shortest. Realize this depends on what forms you're qualifying for the pictures.
  1. Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
  2. '
  3. PictureBox1.SizeMode = PictureBoxSizeMode.StretchImage
  4. End Sub
  5. Private Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
  6. '
  7. PictureBox1.Image = Image.FromFile("C:\BulbOn.jpg")
  8. End Sub
  9. Private Sub Button2_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button2.Click
  10. '
  11. PictureBox1.Image = Image.FromFile("C:\BulbOff.jpg")
  12. End Sub
Jan 05, 2010 | Microsoft Step by Step Visual Basic 6.0...
Vb projects
One of the assignments given for a masters
was to provide an input box for english postcodes (zip fer other places) that would filter out ANY invalid input in as few lines as possible.
With entirely numeric that is simple as it is just a string length
but some countries use alpha numeric and the letters have to be in the correct places eg. wf15 9lf or WF15 9LF or W15 would all be valid but W15 9LF would not..
Again minimal code would show an attention to detail because anyone can write a 100 lines of code to do that try get it in 15 or much less and it becomes more impressive
Specific alpha numeric data input and format sorting always seems to go down well with professors.
I havent given you everything to write the abstract bu the bare bones are there and it gives you an idea of the types of thing looked for.
After all if I gave you the whole thing it would not have been your work.
Aug 25, 2009 | Microsoft Computers & Internet
Create a barcode for F1 and F2 using Labelview
If you have created your barcodes as "F1" and "F2" you will have to create two Advanced Data Formatting rules with the LS2208 Product Reference Guide. This link will take you to the manual. Print only the barcodes you need from the list below then scan them in the order they are listed:
Begin New Rule
Specific String at Start
F (from the Alpha-numeric section of manual)
1 (from the Alpha-numeric section of manual)
End of message (from the Alpha-numeric section of manual)
Send F1 Key
Save Rule
Begin New Rule
F
End of Message
Send F2
Save Rule
That should do it!
May 06, 2009 | Symbol LS2208 Handheld
Out of memory error
1. Use with - End With for values
with xlWbk.Worksheets(1)
.Range(.cells(1), .cells(4)).value = "Some Repeated Text"
end with
2. Use following VB code for killing excle at the end:
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal
lpClassName As Any, ByVal lpWindowName As Any) As Long
Private Declare Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal
hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As
Long
Private Const WM_QUIT = &H12
Sub TerminateExcel()
Dim lpClassName As String
Dim iHwnd As Long
Dim iReturn As Long
lpClassName = "XLMain"
iHwnd = FindWindow(lpClassName, 0&)
If iHwnd Then
iReturn = PostMessage(iHwnd, WM_QUIT, 0&, 0&)
End If
End Sub
Mar 17, 2009 | Business Objects Crystal Reports® XI...
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
Vb code for automatic number change
You want the code for when you press enter in textbox it automatically change to 1.
I am typing C# code you can easly covert it to VB.Net code
make an event for key press for textbox
and write the followting code in the event
IF textbox1.text = ""
textbox1.text = "1"
End IF
I hope your problem will solve with this If need more assistance let me know. If your problem is solved then don't forget to make answer my thread.
Regards
Nov 17, 2008 | Computers & Internet
Access-VB
Use this line below:
Private Sub CommandButton_Click()
Dim NumericValue as Integer
Dim StringValue as String
NumericValue = CInt(TextField1)
StringValue = TextField2
DoCmd.RunSQL "INSERT INTO NameOfTable ( [FieldName1], [FieldName2]) VALUES (" & NumericValue & " , '" & StringValue & "');"
EndSub
I Hope this work for you... God Bless
Jul 16, 2008 | Microsoft Office Access 2003 (077-02871)...
Microsoft Office Project Standard 2007: Windows Logo
728 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
