Question about Toshiba Computers & Internet
I want to fix my laptop built in mouse
I cant move my mouse without having to hold the left bar down, when I let it go the mouse wont move
  • 63 Answers
SOURCE: "sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Posted on Nov 16, 2007
shakeelm
  • 224 Answers
SOURCE: is there a hold button on aspire one the laptop?
Try holding down the "Fn" and press the "F7" key. This should startup the touchpad Mouse again...
Posted on Feb 25, 2009
Crankstart
  • 696 Answers
SOURCE: Automatic scroll does not work on touchpad unless you hold down the left click button
This can be set to scroll for you as it is a simple setting in the mouse control panel.
Go to your start menu and open Control panel, select classic view in the top left corner if there are less than 20 icons(pictures) in the menu. Now double click on the mouse icon. Click on the advanced tab. then select your synaptec device in the list and click the properties button below.
There are several options on the menu, one will say "Virtual Scrolling"
Check the box beside Vertical Scrollong and then click OK on this window and the mouse window.
Close the control panel and you're on your way.
I hope this helps Fixya,
Chris
Posted on May 19, 2009
  • 3940 Answers
SOURCE: The left mouse key broke loose on my HP Pavilion dv6-1234dx
Easy fix, no. The fix is to replace the palmrest assembly. The required a large amount of dissassembly of the system.
Work around
Use a USB wireless mouse
Posted on Oct 10, 2009
SOURCE: my asus mouse freezes, gets stuck and wont move
my touch pad mouse on my asus laptop will only work in safe mode, help
Posted on Jan 21, 2011
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Dont know how to copy and paste
Let's use an example Debbie
-> don't know how to copy and paste
Put your mouse cursor on the d in don't.
Press the left mouse button, and hold it down.
Now move the mouse cursor across the entire sentence, moving to the right.
Stop at the letter e in paste.
Let go of the mouse button.
The sentence will now be highlighted in Blue.
Now press, and hold the CTRL key, and tap once on the c key.
[Small case letter -> c ]
Put your mouse cursor, where you want to paste what you have copied.
In your browser address bar, or whatever.
(Address Bar: The box at top that has the URL in it.
Starts off with www, or http:// )
Now press the CTRL key down again, and this time tap once on the -> v key.
c key is the Copy key, v key is the Paste key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 16, 2013 | Dell Inspiron 2200 Notebook
Acer mouse disassemble ???
The Acer Aspire is a laptop model that has a built-in "mouse pad," also called a "touchpad." The user runs his or her finger across the mouse panel to move the cursor. If your mouse pad no longer responds to your touch, it may be due to a build-up of dirt and grease. Another common problem is having an outdated or damaged mouse pad driver. These problems can be quickly resolved without having to take apart the laptop.
Hold down the "Fn" key, which is found at the bottom left corner of the keyboard. Press the "F7" key once while holding the "Fn" key. Look for a message that says "touchpad enabled." b> Update the Drivers Go to "Start" > "Control Panel" > "System and Maintenance" > "Device Manager." Double-click on "Mice and other pointing devices" to expand the options. Right-click "Synaptics Touchpad" and then click "Search automatically for updated driver software." Wait for the computer to scan and install new drivers. Restart your laptop.
http://www.youtube.com/watch?v=oUyxhcQk6G4 Acer Aspire 5738 7736 Touchpad Mouse Replacement
Jan 30, 2013 | Acer Computers & Internet
My stating button is at the top of my screen how do i adjust
PUT YOUR CURSUR ON THE TOOL BAR THAT YOUR START BUTTON IS ON.
PRESS AND HOLD THE LEFT BUTTON ON YOUR MOUSE.
WHILE HOLDING THE BUTTON DOWN DRAG IT DOWN THE SCREEN TO THE BOTTOM.AS YOU DO THIS YOU SHOULD SEE THE WHOLE BAR MOVING DOWN, PERHAPS FIRST MOVING TO THE RIGHT OR LEFT VERTICALLY AND THEN ON DOWN TO THE BOTTOM OF YOUR SCREEN.
WHILE AT THE BOTTOM RELEASE THE LAFT BUTTON ON THE MOUSE, THE BAR AND START BUTTON SHOULD NOW REMAIN IN THE LOWER SECTION OF YOUR SCREEN..
Jun 23, 2012 | Computers & Internet
Want to move the "menu bar" from the bottom of the
Hi tobrandon...
Hold down left click and move the mouse to the side you want the bar, the release the left click.
Bar will be on side of desktop now.
Do the same thing to reverse the change
Please take time to rate me thumbs up
Sep 11, 2011 | Dell Inspiron Mini 10 Notebook
THE CURSOR WONT MOVE WHEN YOU ROLL THE MOUSE CANT CLOSE WINDOWS DOWN
Hold in the main power on button until the computer shuts down -windows will automaticly safley shut down .
once it shuts down restart it and hopefully the mouse problem will also be fixed
I hope this helps
Andrew a
Mar 28, 2011 | Computers & Internet
The scroll bars on the mousepad don't work
Since it is a Laptop you can not just go over to the Scroll Bar. Move the arrow from the mouse over to the scroll bar. Hold on the left key below the mousepad. The scroll bar should turn a differnt color. Move the scroll bar up and down with your finger,using the mousepad.
Oct 16, 2009 | Dell Inspiron 6000 Laptop Keyboard 0H5639
Somehow I moved the startup taskbar from bottom of screen to the top and now don't know how to move it back
Right click mouse on task-bar and under properties you unchecked "lock the task-bar"
in that window you can chose were to place it ore
left click on the task-bar and hold, then move the mouse to you`r left, right, ore where you want to place it and release mouse key.
Oct 05, 2009 | Dell Latitude D610 Notebook
I Need help with my sons laptop
when starting pc hold f8 button in menu move to last known good configuration enter,if that not helps reply with comment will go further
Jun 13, 2009 | HP Compaq Presario CQ60Z Notebook
Taskbar is on the right side of the screen and not at the bottom. how do i move it back to the bottom
Click you left mouse button  while pointing in the gray area of the taskbar now move the mouse while holding down the button dragging the task bar back to the bottom.
Nov 24, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
