Question about Hamilton Beach Irons
15405 iron is stuck on synthetic
Temperture will not move off of synthetic
2 Suggested Answers
exprich
  • 79 Answers
SOURCE: fleece shirt melted on the bottom of non-stick iron
well try heating the iron and rub the wax on the heated iron and wipe it off using cotton cloth
Posted on Jan 04, 2010
How to clean my iron after ironing wool or synthetics
You can use a wetcloth or use a vacuum to suck it or your hairdryier
Sep 12, 2014 | Irons
Tip
Cleaning a Steam Iron Soleplate
During the day to day use of a steam iron there can be normal buildup accumulate on the soleplate of the iron. Other things such as melted synthetic fibers, iron-on trims, and fusibles can also buildup on the sole plate of the iron. These can be removed with the use of a quality hot soleplate cleaner. Soleplate Cleaning Kits can be purchased from many service centers or can be found online by doing a search for “soleplate cleaning kit”.
If you have had the misfortune of getting melted plastic on the soleplate of your iron, you can remove that by taking a piece of Aluminum foil and sprinkling it with salt. Then take the hot iron and work it back and forth over the salt to break up the plastic and remove it from the bottom of the iron.
Avoid starches and be careful of synthetic materials. Also avoid zippers and buttons that can scratch the bottom of your iron.
Do not use the soleplate cleaners on your iron if it has a non-stick surface. With the non-stick surface you should not need the cleaning anyway. These surfaces can be damaged easily by anything abrasive. Do not use abrasive cleaners on any soleplate. Use the soleplate cleaning kit.
The holes in the bottom of our iron can be cleaned by using a pipe cleaner of a Q-tip.
Simply make sure the bottom is cool and then insert the pipe cleaner or Q-tip into the holes one by one and circle them around inside to clean out the hole.
If your iron has a “self clean” feature, do not over use it. It is recommended that you use it at least once per year, but not more then once per month.
Also look for my other tips on taking care of your steam iron.
on Jul 14, 2010 | Irons
How do get out the boiler chamber on a b25l if it is stuck
First secure the iron so that it does not move (vise, clamps, whatever it takes). Then use an impact driver.
Aug 17, 2014 | Irons
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Apr 01, 2013 | Bosch TDA8340 Iron
How do I clean sticky stuff on the iron plate?
when unplugged and cool, most manufacturers have a sole plate cleaning kit. Try warm water and soap to begin with to remove starch, detergent buildup, burnt synthetic fibers etc. Don't use household cleaners or solvents.
Jul 07, 2010 | Irons
Ironed on synthetic fabric by mistake and fabric melted on the iron soleplate. How can we clean it off? Please Help! Thank you
You could turn the iron on again - set to cotton or highest setting and allow it to completely burn off. Do this outdoors or well ventilated area indoors (no smoke detectors on!)
Or, you could warm the iron and use a plastic putty knife to scrape as much material from the iron as possible. A metal knife will scratch and mar the surface. When cool, use a scotchbrite pad to buff away remaining deposits on the iron.
Mar 12, 2010 | Kenmore ProSteam 62888 Iron
Fleece shirt melted on the bottom of non-stick iron
Jan 04, 2010 | Sunbeam 4237 / 4238 Iron with Auto...
What is the temperature of the synthetic setting?
I would use some scraps of fabric and transfers to do some trial and error experimenting.
Keep in mind that the iron will not produce steam until the internal temperature is 212 degrees farenheit.
good luck with this.
Jan 06, 2009 | Rowenta Professional DM890 Iron with Auto...
Dial stops at "silk."
if the iron is under warranty send it back to the company.if not take down the iron it has a broken part that is stopping it from moving properly.good luck.
Apr 02, 2007 | Rowenta Perfect Iron
Irons Logo
29 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
