Question about Vantage Point Televison & Video
How to take down a vantage point ptw 13b. I need take down this wall mount and I can't figure out how to get that round cap off the top
2 Suggested Answers
  • 15 Answers
SOURCE: How do I mount my bath boutique vantage mirror
There should be a back plate on the base that attaches to the wall...use some wall anchors if your not screwing the plate into a stud. The base should then attach to the back plate with 2 screws i imagine.
Posted on Jun 08, 2010
How do I round 439.96479 to the nearest cent
take the figure immediately after the decimal point (disregard the rest) and see if it is less or greater than 5. If it is 5 or greater then round up to the next figure before the decimal point
if it is less then round down to the whole figure before the decimal point
example if the figure is 439.5 or 6 or 7 or 8 or 9( disregard the rest of the figures) it is rounded up to 440.0
it is 439.4 or 3 or 2 or 1 then it is 439.0
Feb 12, 2015 | Computers & Internet
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
How do I turn on the heat?
The remote should have a mode setting for heat or cool.
Oct 24, 2013 | ComfortStar CHH018CD-13B Wall Mounted Mini...
My fluidmaster 747 in a Kohler low tank is shooting water and running down the front of the tank with every flush
Twist the Blue top cap counter clockwise. This will remove the top. Inside, you will find a white round rubber piece that has most likely become dirty and stiff. Push the round upper cap up and down with your thumb in the middle of the top rounded part of this piece. Once the piece seems softer and more flexible, if you have already cleaned it, place it back into the top of the fixture with the smaller round end down. Place the cap back on, rotate it clockwise until it clicks in secure. At that point, it should work fine and the water squirting out of the top should be stopped or reduced significantly so that you can continue to use the toilet.
Feb 13, 2011 | Plumbing
I have a Grohe 28917 Relexa Ultra Five 24 Inch Shower Set, and it is not mounted well to the wall so that it is loose. Also, the slide bar also goes up and down too easily. Can you help me?
the 2 mountings have caps on them, pop them off to get to the screws. If the plugs in the wall are busted you can use spring toggle bolts and it will give you a very strong mounting. Just don't over tighten to the point that you damage the wall.
The slide bar may need rubber cleaned since soap scum will make it slippery. Do this while you have the bar off the wall.
Jun 05, 2010 | Grohe 28917 Relexa Hand Held Shower -...
How do I mount my bath boutique vantage mirror 15200 - there are no instructions and I can't figure out how it works
May 20, 2010 | Home
Wiring diagram for distributor cap
the old fashioned way to check this is to remove your distribution cap and watch the position of your rotor arm to see which position it is for cylindar 1. then take out the spark plug for cylider one and use a light to see inside you should be able to see the piston move up and down throgh the hole, now the piston only goes down twice in one cycle so by cranking the engine round by hand you can correspond where the piton just starts to go down is the point of ignition so the rotor arm should be at the same point lined up with the spark lead for cylinder one inside the cap. if it mile off then cylinder 1 is at the top of the induction stroke, so crank round again until the piston starts to go down again. then you have the distributor arm at the right position, then follow round the cap the firing order for your engine. and then wire up the cap the same way.
Nov 14, 2009 | 2000 Dodge Durango
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 01, 2009 | Samsung SM932MW 19 in. LCD TV
The screen goes complete blank with sound still on. It takes to shut TV off and power it on right away to get picture back-though the intervals getting shorter down the road . MY Screen goes black and I...
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
Jun 01, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Televison & Video Logo
44 people viewed this question
Top Vantage Point Televison & Video Experts
Electro Med Services...
Are you a Vantage Point Televison and Video Expert? Answer questions, earn points and help others
