I have four green lights and one blue on my Ubee modem?
On my display I have four green lights and one blue how can I turn the blue light to green?
4 Suggested Answers
Verizon
  • 14 Answers
SOURCE: Actiontec (GS503AD3-01) Modem
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Posted on Jul 11, 2007
krohiti
  • 78 Answers
SOURCE: ST516v6 Modem has all lights except the Internet.
Check your IP address, go to start... run... cmd... and type in ipconfig... if your ip address is 169.xxx.xxx.xxx then you need to troubleshoot on your computer.. get a local tech to help you out.. if not then the ip should be 192.168.1.xxx thats the residential gateway....
was i help ful?
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: (1000-000057-000) Modem: Modem will not turn all the green lights on...
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at abotu 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
Posted on Jun 09, 2010
What is a bonded channel signal
A 'bonded channel' is where the modem combines two or more channels together, for increased bandwidth.
The first light <Power> should be green, indicating power is on.
The second <Receive> light can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for downloading. That is too say, it is bonding(higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The third light <Send> can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for uploading. That is too say, it is bonding, (higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The fourth light <Online> is green, only....
If green and flashing, it is scanning for a connection.....
If green and not flashing, it is finished scanning....
The fifth light is the WiFI indicator of network traffic. (It also is used for WPS pairing, which I doubt you will use. Just stick with the WiFi indicator function...). It should be green, normally..., or non-WPS....
If #2 is blue, and 3# is green, normally...., I suspect that there is too much loss in your in-house system of wiring, and splitters. If that is the case, try putting a 8-12dB 'tap', in series with the whole house. That way, the loss is minimized for your modem to 'send' high bandwidth stuff upstream to the cable guys.... Be sure that the modem is connected to the 'tap' port, the house to the 'out' port, the cable company to the 'in' port of the tap block. I pasted a couple of examples of taps, at the bottom of this, to show the port labels. The tap loss to the rest of the house, is minimal to how well everything else works. I get a +15dB signal from the cable company. But, too many splits, left my modem in low speed upload mode. By-passing the splitters of the house, by adding the tap as only loss to modem uploading, my blue light always stays on. I also added an UPS, to cover power failures, and glitches. That was a well spent $50 special!
a3e73f03-c380-49da-8c63-30f45940ca66.jpg ef068fc8-f053-49ce-a577-d352db809e0b.jpg
Jul 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Forgot my password
Did you change the password from the factory default? If not, try these three.
1. root/root
2. user/user
3. admin/cableroot
Otherwise, you can do a hard reset, by pressing and holding the reset button on the back for about 10 or 15 seconds.
You might want to check with your ISP before resetting it though, some require a technician to go out and set it up again.
Apr 23, 2014 | uBee New Ddm3513 Docsis 3.0 Cable Modem -...
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((ยท)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Ubee router
You may want to try resetting the modem and router. The only light that should be blinking should be the data light. A steady blinking link light typically indicates the router is attempting to establish a link. Modem may need a reset or potentially a problem on your ISP's side.
Nov 15, 2013 | Computers & Internet
What is the username and password for the brighthouse ubee
You are able to access some of the modem/router settings using the credentials:
User Name - "user"
Password - "user"
Without the quotes, of course. This will not give you complete access, however, it will allow you to modify a fair amount (not in my opinion) of settings and view various modem/gateway information pages.
Unfortunately, Brighthouse (BHN) is on their game, when it comes to locking certain features/settings from being changed by the consumer. Time Warner Cable (TWC) sold select areas to BHN some time ago. TWC is a bit more open to user changes.
For example, TWC and BHN both supply the modem/router Ubee DDW3611. TWC's supplied unit's configuration can be accessed by the customer through the 'User' account and the 'Admin' account. BHN, on the other hand, only allows the customer to access the configuration through the 'User' account-which limits the available configuration options.
TWC units may be accessed through the 'Admin' account using the following credentials:
User Name - Last 8 characters of the Ubee Modem MAC Address
Password - c0nf1gur3m3
For example: If your Ubee Modem MAC Address is "1C:6D:CB:14:D6:4A"
Your 'Admin' credentials would be:
User Name - CB14D64A
It is very unlikely that the aforementioned credentials will work to log in to the 'Admin' account for BHN supplied units. But hey, its worth a shot. Right?
Hope this helps.
-James.
Aug 12, 2013 | Computers & Internet
How can I change wireless password
From LAN side login into 192.168.0.1 or 192.168.100.1, user & password should be provided by your service provider but could be admin / cableroot, once there go to Wireless menu and under Primary Network option you can change your password.
Sep 04, 2012 | uBee New Ddm3513 Docsis 3.0 Cable Modem -...
I have a comcast ubee cable modem model U10C018.89. For some reason I can't get my wireless router to communicate with the modem. How can I set up my router with my modem?
Of course, the uBee modem works charmingly, no doubt about it, you can read more here http://wirelessroutersreviews.com/ubee-formerly-ambit-u10c018-docsis-2-0-cable-modem/
Nov 06, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I need a wiring diagram for a 2001 ford f150 trailer hitch plug in. i got a new heavy duty trailer connector and i need to know the color code of the wires
Hey Bryan
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
May 02, 2009 | 2001 Ford F150 Styleside SuperCrew
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Trailer wiring
Hi Smokey,
Six wire plugs:
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Jun 29, 2008 | 2005 Ford Five Hundred
Computers & Internet Logo
David Payne
David Payne
