Question about Sharp R-216 800 Watts Microwave Oven
Repair manual for a sharp r 1471 - Sharp R-216 800 Watts Microwave Oven
Manual for sharp carouselgrill2 convert-microwave
FINDING OWNER'S MANUALS
If for some reason you don't still have your manual, here are ways to get one:
Look at the model number tag and find the FCC ID number.
Enter the number (in two parts) as shown on the FCC ID page here:
https://www.fcc.gov/oet/ea/fccid
In the list of exhibits, look for the owner's manual. You can download it free.
If it's not there, you should be able to order it via the links on my part ordering page here:
http://www.microwavecontrol.com/parts.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 03, 2017 | Sharp Microwave Ovens
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
User manual for a model R-209 AK counter top carousel microwave
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Top Automotive Device Types ..... Sharp M I C R O WAV E O V E N OPERATION MANUAL. Pages: 0 ... Sharp Microwave Oven 209H ... SharpOperation Manual Microwave Oven R-308H, R-305H .... Sharp Microwave OvenMODEL R-2197 ... Sharp over the counter microwave oven operation manual ...
SHARP MICROWAVE OVEN Parts ' Model r209ak ' Sears ...
www.searspartsdirect.com/model-number/r209ak/0958/0123245.html
Shop for SHARP MICROWAVE OVEN repair parts for model r209ak at Sears ... Find part in diagram SHARP Countertop Microwave Model # R-209AK.
Jan 07, 2016 | Sharp Microwave Ovens
When door is shut light comes on but does not start microwaving. I can make it start by holding the door up from the bottom. How to fix?
We had a guest for a repair at our Repair Cafe last week, and he did have a Sharp Microwave, that had the same problem. Maybe looking into the manual will help, see url Sharp 319F Operation Manual
Feb 13, 2014 | Sharp R-319FW Microwave Oven
I need to know the dimensions of a sharp r-1471 microwave. Mine has stopped working and I want to make sure the replacement will fit
29 15/16" W X 16 3/8" H X15 1/4" D (outside dimensions)
I copied this from my Sharp Carousel Operation Manual as I just
had to replace my 13 year old microwave.
Apr 04, 2012 | Sharp R-1480 Microwave Oven
Where is the monitor switch on a sharp r-1471
You can check the protection diode fitted across the highvoltage capacitor near to the Highvoltage transformer. If it is shorted there is a chance to blow off the fuse. There is no chance for the monitor switch. Any way you can check the monitor switch which is located near to the control panel( Near the door switch)
Jun 04, 2009 | Microwave Ovens
Sharp Carousel #R-209 E KA stored for year.
press stop/clear, set the clock to any time.
Now your oven is working, Bingoooo
Mar 28, 2009 | Microwave Ovens
I have a sharp r-57m/r-95stm microwave. all of a sudden whatever time you put in, it will only do a minute. no info in the manual. inconvienent having to keep going back to it. please help.
mine does the same,started couple of months back checked it out with repairs and surply result....fxxxed get a new one to expencive to repair
Jul 14, 2008 | Sharp Microwave Ovens
Sharp R-216 800 Watts Microwave Oven Logo
29 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
