Question about Kenwood KAC-9152D Car Audio Amplifier
My amplifier goes right into protect when the power,remote,and ground wires are hooked up i didnt even get to hook up the speakers which are a 2ohm load what the problem and how can i fix it?thanks
    Habit-Forming:
  • 187 Answers
If 12V is present
contact Kenwood repair for estimate of repair
Posted on May 19, 2009
I have an xterminator xt2000d amplifier which is stuck on protection mode. It keeps on trying to switch over to full power but stays in protection mode. I unplugged speakers same thing replace fusses same...
sometimes the problem isn't noticeable. it could be a problem in the circuitry itself. how old/new is the amp? is the ground solid? what gauge is the wire? try hooking it up to the battery directly and instead of hooking up the remote wire from the head unit to the amp use a "jumper" (short wire) to connect it from the amp power wire terminal to the amp remote terminal. if its still in protect after that then the amp is bad and needs repair...
May 31, 2011 | DHD US Amps Xterminator XT-2000D
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
I have the subs hooked up to the amp and the speaker wires from the cd player connected, when i hook up the ground and power nothing happens.. sometimes the protect light comes on..? help..
LETS SEE IF YOU HAVE A PROBLEM WITH THE AMPLIFIER ITSELF OR IF SOMETHING IN THE INSTALL REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION OR FAILS TO POWER UP AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. SOMETIMES THE RADIO CAN HAVE A DEFECTIVE SAGGING BELOW 11 VOLTS REMOTE OUTPUT WHICH WILL CAUSE THE AMPLIFIER TO NOT POWER UP. IF YOU DISCONNECT THE RADIOS REMOTE LEAD AT THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER FROM THE POSITIVE POWER TERMINAL AND THE REMOTE TERMINAL OF THE AMPLIFIER, THIS WILL NORMALLY FORCE THE AMPLIFIER ON. AT THIS POINT,YOU HAVE TOTALLY BENCHED THE AMPLIFIER AS IT WILL NOT HAVE ANYTHING TO DO WITH THE ACTUAL INSTALLATION AND IF STILL FAULTY IT SIMPLY WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 13, 2009 | Legacy Audio LA770 Car Audio Amplifier
My amps protection circuit keeps cutting on and off when i hook up my amp
Hello m_george191,
Usually an amp will go into protection when there is a problem with the wiring, impedance load, or when overheated. Immediately when hooked up, it probably isn't overheating.
Most likely, there's a short or ground on a speaker wire, an input, or a faulty ground to the amp itself. Frayed or broken insulation, stray wires shorting across the terminal blocks, and shorted voice coils can all cause the protection circuit to activate.
First check your power and ground wires. Then disconnect the speakers and inputs and see if the amp powers up normally. If the amp still goes into protection with all wires other than 12V +, Ground, and Remote disconnected, the amp itself is defective. If it powers up normally with all other wires disconnected, reconnect the inputs one at a time to determine if one of them causing the problem. Likewise, reconnect the speaker wires one at a time.
Hope this helps.
Aug 31, 2009 | Rockford Fosgate Punch P325.2 80W x 2 Car...
Protect light comes on, no power
Hello patrick_h_mi,
You'll also need a remote turn-on source for the amp to operate. Normally, this is a blue or blue/white wire from your head unit, but for test purposes, you just need 12V to the "remote" terminal on the amp. The amp should power up without speaker inputs or speaker connections, but it is not recommended.
Hope this helps.
May 28, 2009 | Infinity 7540A Car Audio Amplifier
Let our Experts solve your "My amp lights up like normal then protection light red comes on and turns the amp off resets and tries again. What would be my course of action
disconnect all wires (including RCAs)
reconnect positive, ground, and remote.
Turn amplifier (car) on.
If it goes into protect mode again - there is an internal fault that requires professional repair.
If the amplifier idles as normal - turn off the car. Plug in RCAs & re-try
Failure? - replace RCAs as they may be pinched or faulty.
Lastly if all connections are made and amplifier idles without going into protection - you need to concentrate on your load (subwoofers).
Be sure they are wired properly into a resistance that amplifier is rated.
The lowest impedence that amplifier is rated is 2ohm.
That is possible with (2) 4 ohm subwoofers wired in parallel....
(4) 8 ohm subwoofers wires in parallel...
(1) Quad 1 ohm subwoofer...
or (1) Dual 4 ohm voicecoil subwoofer.
Any other combination will result in an impedence too low for your amplifier.
Next:
Using an OhmMeter (Digital multimeter set to Ohms 20) test each voicecoil against its advertised resistance. It should be CLOSE +/- .5 Ohms.
Any other reading means the voicecoil is blown.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 27, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Amp doesnt turn on.
it sounds like it is blown..one way to test it is put the remote wire and the power wire together and put it to the possitive of a drill battery and the put the ground to the nagitive at the drill battery..if it goes right to protect then it is blown!
Mar 04, 2009 | Directed 1100d Car Audio Amplifier
Amp protection
Does it go into protect if you disconnect the speaker wires from the speaker terminals of the amp?
Feb 16, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
142 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
