Question about Singer Sewing Machines
Machine frozen I hear sound but machine will not move parts to sew.
    Novelist:
  • 268 Answers
Switch the bobbin winder on and then off again, crisply, or turn the knob in the middle of the handwheel to tighten the clutch. If still no response, your machine may have a broken belt or be seized from lack of proper lubrication.
Posted on May 25, 2014
2 Suggested Answers
killycasas
SOURCE: My sewing machine is stuck after I refilled the
I was wrong. I thought there was something wrong with the top part of machine because I kept hearing a noise when I step on the pedal. Turns out the problem was on the bottom. The little part where the bobbin goes it has two little circular thingies that were not aligned correctly. Once I corrected this the machine works perfect again.
Posted on Oct 15, 2009
Testimonial: "SAME PROBLEM' THANKS!!!!!"
My Pfaff 1222-E Sewing Machine seems to have frozen up, what can be wrong. It is Old purchased in 1976
It probably is frozen due to lack of regular cleaning and oiling. The old oil turns to glue preventing the parts from moving like they should.
Apr 15, 2018 | PfaFF Sewing Machines
I have a Necchi model 537FA. When u step on petal, it won't move. Does this machine have 2 BELTS? I only see one. I have oiled before running.
If you don't have any movement or hear the machine attempting to sew, you may have a burnt out pedal.
You should hear a slight hum when pressing on the pedal. If you don't hear a hum, the pedal is probably dead.
These can usually be ordered from the merchant who sold you the machine.
Apr 19, 2016 | Necchi Sewing Machines
Where are the oil ports on an old Kenmore 10 sewing machine #12511..thanks
If your older Kenmore is mechanical (not computerized), it probably can use a bit of oiling beyond what the manual recommends. Older machines frequently were pre-oiled at the factory, however, after many years, the oil tends to dry out and cause the mechanical parts to stick (the reason most older machines are frozen). Perhaps this link will be of help:
It was working now it seems to be frozen the needle part wont move
Feb 10, 2016 | Kenmore Sewing Machines
The Stitch Selector seems to be stuck and it will not move. Also the Stitch Length wheel is also very diffiult to turn. Please help!
If you can provide the brand and model of your machine, it would be easier to help you.
Is your machine is an older mechanical machine. If so, how long has it been since you've cleaned and oiled it? Sounds like the old oil has solidified and frozen the moving parts.
Consult your owner's manual on cleaning and oiling your machine. Use only good quality sewing machine oil (not 3-in-1, WD-40, or cooking oil), and apply only one or two drops to each spot.
Jul 21, 2015 | Sewing Machines
The wheel wont turn to be able to sew on my Brother VX 1200. I can do it by hand but when I press the pedal, I can hear it whine, but it wont move. Thoughts?
I'm not familiar with your model sewing machine, but if it's been setting for quite some time, chances are it is frozen. If you have your manual, see if there are any oiling instructions and follow those using a Good Quality sewing machine oil (not the old brown stuff you probably current have in your sewing kit--it's old and should be thrown out). Sounds like maybe any oil it had has dried up and turned to glue. If so, you need to get that loosened up before the motor can have enough power to move things. If your machine is mechanical (not computerized), you can probably heat up the internal mechanisms with a hand-held hair dryer.
Feb 23, 2015 | Brother Sewing Machines
How do I fix or clean my sewing machine after I sewed a non sewable applique adhesive?
I DID THE SAME THING WITH STICK ON VELCRO. WHEN THE NEEDLE STUCK IN THE ADHESIVE IT PULLED THE PART BELOW THE BOBBIN HOLDER OUT AND IT HAD TO BE REPLACED. PRICEY REPAIR AND LESSON LEARNED.
Jul 19, 2014 | Brother Sewing Machines
Singer 401A gears will not move. I can wind bobbins all day but the gears to sew are frozen they try to move but will not.
the gears or some part in the sewing machine could be damaged, I suggest having the machine checked to see what is wrong inside the machine hindering it from sewing.
Aug 21, 2013 | Singer Sewing Machines
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
Jun 26, 2013 | Sewing Machines
I was given a baby lock #5280. It had been serviced in 2007, but has not been used since then. The moving parts were frozen, but some oil has loosened them up a little bit. The motor sounds healthy, but...
For that length of time you need it professionally cleaned and serviced. Timing is the important bit, each component has to be in the right place at the right time to sew correctly.
Google
<your city> sewing machine service.
Jan 01, 2018 | Baby Lock Evolve
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
