Question about GE CFCP1NIZSS
Frezzer cold but not refrigerator - GE CFCP1NIZSS
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works fridge doesnt?
most likely defrost problem . most refrigerators getting their cold air from the freezer, so if your frezzer frost up, no air gets to fridge side, u have to remove the frezzer panel and inspect the evaporator coil, if frosty, u have bad defrost system, which part is bad? depends on the brand and model.
Oct 31, 2009 | Dometic RM2852 Refrigerator
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Frezzer to cold and Frig is cold a little
Dear customer,
                     It maybe the makfunction of defrost timer howevet we recommend you to do the following before checking the defrost.
  1. Check the temperature setting
  2. Test the  temperature control
Click on the highlighted words to know how to test them.  If they seem to work fine then check defrost timer using the reference link  http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosttimer.php
Thank you..
May 07, 2009 | Refrigerators
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
GE CFCP1NIZSS Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
