Question about Chaney Instrument Chaney Acu-Rite 1500 Professional Wireless Weather Center with Solar Powered Fan Aspirated Sensor Pack
Rain reset for acurite 1500 . is there a reset
Is there a way to reset the total rain fall amount on the acurite 1500 weatherstation. it stops at 99.99 inches
What was the total rain fall amounts for Tarpon Springs November 2016
https://daily-weather.weatherdb.com/d/a/Tarpon-Springs%2C-FL
Mar 07, 2017 | The Computers & Internet
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
What is the rail fall amount for may in Ellenbrook Perth W.A
I finally found some form of daily records for perth
http://www.bom.gov.au/climate/current/month/wa/perth.shtml#daily
Jun 09, 2016 | Measuring Tools & Sensors
MONTH AND DAILY RAIN TOTAL ARE ALWAYS THE SAME EVEN AFTER A MONTH
Try going to the rain section, push the + BUTTON 5 times, and then on the 5th push, hold the button for 3-5 seconds and the guage will reset to 0.
Mar 28, 2014 | Acu-Rite Acurite Wireless Weather...
Flashing rain today and total rein
I have the same problem and would also like an answer to this
Jan 30, 2014 | Oregon Scientific RGR202 Wireless Rain...
How do i reset digitech indoor/outdoor weather station rain reading manually?
To reset the rainfall Press Set 4 times so the rainfall amount is flashing. Change the rainfall indicator to Total, then hold down the set button for 3 seconds.
Jan 23, 2013 | Measuring Tools & Sensors
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Jan 15, 2013 | Measuring Tools & Sensors
Chaney Instrument Chaney Acu-Rite 1500 Professional Wireless Weather Center with Solar Powered Fan Aspirated Sensor Pack Logo
210 people viewed this question
Top Chaney Instrument Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Chaney Instrument Measuring Tool and Sensor Expert? Answer questions, earn points and help others
