Question about Refrigerators
Feeler arm will not stay up to stop ice production
Whirlpool #wrf5355mbm
  • 54 Answers
SOURCE: Broken ice maker in a GE side by side refrigerator
Most of the time the spring just pops out of the keeper on the ice maker, If you push the feeler arm back and it does not come back out on its own then the spring has poped off. Look where the feeler arm attaches to the ice maker and there is a round spring between the feeler arm and the icemaker housing. There is one hole in the feeler arm ans one on the ice maker housing that the spring pops into. Its usually the spring is out of the hole on the ice maker housing.
Posted on Jul 03, 2008
  • 489 Answers
SOURCE: Icemaker not making ice - feeler arm in up position
You may have a broken icemaker and needs to be replaced.  The internal parts are solid state electronics and they can break.
Posted on Sep 30, 2008
Maytag317
  • 1136 Answers
SOURCE: feeler arm on ice maker prevents freezer drawer from opening
Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
Hope this helps. Please let me know if I can help further.
Vic
Posted on May 11, 2009
mitchjl_1692
  • 3 Answers
SOURCE: Icemaker won't make ice
Try using a hair dryer.Arm may be froze up.mitchjl_1692
Posted on May 27, 2009
  • 113 Answers
SOURCE: My LG LSC27931 REFRIGERATOR It is not making ice.
1st check to see that the ice filling hose is not frozen. It is usually a finger sized tube at the top of the fridge behind the ice maker coming out of the back wall. You can use hair dryer to melt plug. Many ice makers start their cycle by harvesting ice that has frozen. There is a sensor that is attached to the bottom of the try that the ice freezes in. If it goes bad your machine will not harvest or refill. Solenoid that lets water into fridge may not work... Valve behind fridge or under sink that supplies water to fridge could be turned off or plugged. I suggest that you go to an appliance parts store and purchase a service manual for your ice machine.. Most parts house have many such manuals.
Posted on Sep 22, 2010
Whirlpool mod#ED5FHEXNB00 isn't making ice
Freezer temp has to be below 10 degrees for ice maker to work. Also check to see if water/ice is in the tray. If no ice in tray then the water solenoid valve is not feeding the unit. If ice in tray then the heater is not working to melt the ice a bit so it can be scooped out into the ice tray. And make sure the feeler arm is down into the ice tray bin - if not, ice maker is shut off.
Oct 05, 2015 | Whirlpool Refrigerators
Why does Whirlpool G16FARXXF05 refrigerator not dump the ice?
as I remember them there is a small heater that warms the bottom of the ice maker so the ice is loosened a little perhaps your timer or heater has gone kaput
Jul 20, 2015 | Whirlpool Refrigerators
My ice machine will not stop dispensing ice, what's wrong?
There is a feeler arm that feels for the cubes in the ice tray. If it is not working or has fallen off, the machine will continue to make ice non stop
Mar 17, 2015 | Kitchen Appliances - Others
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Need to know how to turn on ice maker in whirlpool gz25fsrxyy2
Should be a wire feeler arm that runs front to back on that icemaker. If it is stuck in the up position---the icemaker is OFF. It should be hanging downward to be in the ON position. If up---just gentley pull it down until it is moving freely. As the ice bin fill with cubes that arm should move up and down with the icemaker. Once the cube level is high enough for the feeler arm to be held in the up position it will stop making ice until you use enough cubes for the arm to fall again.
Sep 26, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Jun 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker not going through complete cycle
what kind of unit is it? there are several possibilities
May 07, 2008 | Refrigerators
Ice maker does not stop working and overfills, then ice dispenser does not work and pushes door open.
Continuous ice production, too much ice in the bucket, ice cubes overflowing the bucket, ice cubes falling behind the bucket or ice lifting the chiller shelf can now be resolved by installing a redesigned feeler arm. The new arm is designed with a slight curve to cycle the icemaker “OFF“ before the cubes overflow the ice bucket. Order part number WR49X10103.
Jan 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
