Question about Apple MacBook Mac Notebook
While typing document suddenly a colorful spinning circle appeared and can no longer do any work. it has been spinning for 45 minutes, what does it mean?
  • 864 Answers
That's the "beachball".  It shows that the system is occupied with some background processing and does not have enough capacity to process your latest input.  It should eventually stop if you leave it alone. You could do a force quit but will lose any current data that has not been saved.  You may have to have the hard disk checked and optimized.  Use Disk First Aid or Disk Utility in Applications/Utilities folder to check the disk.
Posted on May 20, 2009
How to remove a little circle of color in spinning
Ctrl+Click on the icon in the dock and select force quit. Make sure you don't have too many other processes running at the same time.
May 14, 2014 | Apple MacBook Pro Notebook
How do I fix concentric color circles on Jvc av 2779s?
AV2779S--the 27 means it is a 27 inch and a older one at that.
All the older regular sets have a Degausser in them--a coil as thick as your index finger--each time the set is turned on it demagnetizes the face of the tube--happens so fast you never see it.
This circuit consists only of a few parts--most common failure is the posistor (a small black rectangle near the main fuse) breaks loose from the board.
It only has 3 connections on the bottom and does get rather hot--my money is if someone locates it and looks on the bottom of the board one or more of the 3 connections is broken loose.
What will happen is with a bad connection there when set is turned on the Degaussor does not completely finish its job before it cuts off.
If I am right--someone with even moderate skills, a soldering iron and solder gets the board out and 5 minutes later after resoldering all 3 connections----wait 60 minutes plus for Posistor to get totally cool will have a normal picture again.
Comments or Question?
Apr 06, 2012 | Televison & Video
I was browsing on the net then the colorful circle appear and just started spinning and will not let me do anything. wont even let me turn the computer off. what is this????
Power down. Take your RAM out and re-insert firmly. Nothing? Take your RAM out and look at it to make sure you got the right type of RAM for your Mac. Nothing? Buy new upgraded max RAM. Recommended brands are OWC, Crucial, and Samsung. Get 2 GB of RAM to put in each slot and that should help you out with the colorful spinning wheel of death. The wheel shows up whenever the program your using does not have enough memory to allocate for the resources your using.
Also, you can take disc 1 of the 2 gray discs and go into disc utilities and do a repair permissions and then do a repair hard drive.
Nov 17, 2010 | Apple MacBook Pro Notebook
How can i unhighlite the text in macbook word 2008
JUST READ THROUGH
Just wondering if anyone else was having issues with Microsoft Word from MS Office 2008, where you open the application, you type a few sentences, and the application freezes with the spinning circle of death that won't go away until you click the dock where it says "application not responding" and do a force-quit? You can leave the circle spinning for 10-20-30 minutes, and it never goes away.
Now for the weird part--this error only happens for me when I'm using a specific document on my computer. I can open Word, start a new document, type several paragraphs of text, and it works fine. But I've been working on an existing paper for about two months that all of a sudden started causing these freezes/crashes when editing it. It's about 30 pages roughly, no images, no big inserts that would take up a lot of memory (116 kb in size). And up until today, there were no problems. So why all of a sudden can't I edit anything on this paper without freezing the program?! I downloaded the Microsoft Office 2008 Service Pack 1 that was just released after this problem started, and ran all the recent Java and program updates through Software Update with computer restarts. I even copied the text from the Word document I was working on, pasted it into a new document, tried saving it as both .doc and .docx, and again the program still freezes when working with that text in a new file. This one baffles me. It's like the text within a document is somehow freezing the application. One thing I did notice is that the freezes seem to happen when I'm scrolling using a mouse wheel. Not always, but quite a bit. I suppose this is some memory issue related to several pages of text that the program can't render or process when you add new lines of text or scroll, but again, I can't figure why this paper I've been working on for months all of a sudden decided to start freezing Word today. Can you really only have 30 double-spaced pages of text in Word before it crashes?
Looks like I've found my reason to switch to Open Office, since I'm 3-4 days out from a
Sep 23, 2010 | Apple MacBook Mac Notebook
Long pausing when typing or scrolling
your computer is obviously abit stuffed up there is nothing you can do so just get it repaired i wish i could help sorry please rate this solution...:)
Jun 06, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Scan Color document by Toshiba E-Studio 45
E-studio 45 or E4500 is a black and white copier. Hence, it can only scan original document to black and white only. There are some copiers which have the color scan capability but not this one.
Feb 03, 2010 | Toshiba e-Studio 45 Black and White Copier
A rainbow circle of color has suddenly appeared on the screen,
if there is a speaker near the set it will draw the color out
Jul 09, 2009 | Panasonic TH-42PZ77U TV
Weird colors on my tv
If it is a tubed TV the spot suppressor is no longer working.
Mar 07, 2017 | Sharp Aquos LC-32D40U Television
HP 7210 OfficeJet - unnecesary cartridge messages
We had the same problem - after 2 1/2 years suddenly the dreaded dialog boxes appeared out of nowhere! We had tech support on the phone for at least 30 minutes to no avail. Finally we uninstalled and reinstalled the printer and all software and it disappeared.
Good Luck!
Apr 05, 2008 | HP Officejet 7210 All-In-One InkJet...
Apple MacBook Mac Notebook Logo
171 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
