Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
Compressor keeps shutting off after 30mins or so
Hi, I have a LG split A/C and whenever the temperature is above 40 celcius i've noticed that the compressor keeps turning off after every 30 mins or so and then comes back ON after sometime. The indoor unit shows that the compressor is ON but the air coming is not cold at all. I have also noticed that this happens more during the day than at night.
I have already got it checked and even the capacitor had been changed but still the problem persists. Please help me cause i really don't know what to do?
  • abhishek_ban May 19, 2009
    Hi, thanks for your reply. but i have another A/c by Haier also Split and it works fine in the same temperature so how could this LG A/C be getting overheated? Is the compressor faulty??
  • abhishek_ban May 20, 2009
    Hi, just to follow up yesterday the temperature dropped a bit to around 30-35 celcius and the AC was working fine and kept cooling without giving any trouble. But couple of days before that when the ambient temp was between 40-45 celcius i faced the problem which i mentioned above. Does this not show that the AC compressor is overheating when the ambient temperature is higher than 40?
    President:
  • 2,559 Answers
The system may be going into cool down mode or thermal over load if the temperature is 104 degrees fahrenheit or above since the compressor will shut down if the internal temperature reaches 165 degrees.This could also be from low oil in the compressor.
Posted on May 19, 2009
  • Randy Hough
    Randy Hough May 19, 2009
    Thermal overload is due to the internal temperature as has nothing to do with outside temperature,There are multiple causes for this to occur.
  • Randy Hough
    Randy Hough May 20, 2009
    That is exactly what I would expect,If the internal temperature on the compressor is near thermal overload,The higher the ambient temperature,The faster it will over heat and the lower the ambient temperature the longer it takes.If the ambient is low enough to dissipate the heat effectively,the unit can operate perfectly. You can help with the heat dissipation by making sure the coils and filter are clean, the return vents are free from obstruction, the unit is properly charged with oil and refrigerant,and there is nothing close to the outside unit that would limit air flow(the unit should have at least 2 feet of free space around at least 3 sides for proper air flow)
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
My split system keeps kicking out it runs for a while if i shut down and restart but compressor kicks out after 5 min. it is contrlled with remote
The unit is usually low on freon when this happens...the machine will over ride the freeze stat and the low pressure control for five minutes and then shut down...
Have a tech. check the system for leaks and repair them.
Then recharge the system and you'll be good to go...
heatman101
Jul 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
I have a split unit that drips water whenever the compressor shuts down.
The unit is probably low on freon....this causes it to build some ice while running. Then when the compressor shuts down it will melt off the coil and drip...
Get the refrigerant charge adjusted properly and you should be okay...
heatman101
May 18, 2011 | Goldstar Heating & Cooling
My freezer motor keeps running and wont shut off.what can i do to fix my problem?
The freezer or evaporator fan runs whenever the temperature controls is closed and the compressor is running. The control may not be getting satisfied and continues to call for cooling or there is a possibility that there is a short in the wiring. If the refrigerator temperature is not below 40 degrees it cold mean there is a problem with the sealed system.
Jan 04, 2011 | Whirlpool ET6JTKXK Top Freezer...
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Air conditioner compressor keeps shutting down
This is due to thermal overload,Which can be caused by low oil in the compressor,the fan has stopped running on the unit outside,Dirty coils,or just a worn out compressor.Although this is thermal overload,It has nothing to do with outside temperature,But rather the internal temperature of the compressor itself.
May 19, 2009 | LG Heating & Cooling
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
New install. 40 seconds on. 20 seconds off.
Its normal that the air coming out is warm cause you set it to heat mode. Check your setting temperature, it is normal for the unit to shutdown when it will attain the setting temperature and operate when the temperature is lower than the setting temperature(heat mode).
Mar 05, 2008 | GE Quiet-Aire Ductless Split System Air...
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
1,986 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
