Question about Thomson 21DC320 21" TV
Thomson tv, model quadra 21
Picture is narrowed both side vertically. whether any adjustment can be done through remote. recently eht was replced.
  • joydip Nov 01, 2007
    no change
  • Anonymous Apr 08, 2009
    How to reset the tuner into tv..
  • 93 Answers
Reset the memory of your tv,or the EEPROM.to reset it just simply unplug the unit,then press together the menu and the vol+ buttons,then press the power switch,when its on,release together the from pressing menu and vol+
Posted on Oct 19, 2007
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
Sony Trinitron XBR 36 in (TV control on Top Middle of set) (set-up / tv/video / vol / channel / power) when set is powered on the standby/stereo light Continuous blinks red once a second, no pausing -...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is exactly as you have described .....after few seconds picture comes slowly & immediately (after few seconds). it gets off only red light blinks............ .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore ..since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally .....GUARANTEE....... vishnuswamy_4.jpg
Jul 24, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have a Sony KV-35S26 manufactured Aug '97. The picture comes ON only occasionally. When it fails to come ON, the standby light blinks continuously. Sometimes, the picture comes ON initially then...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 14yrs old itseems TV TUBE is still in good condition because you have said that whenever display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
May 22, 2011 | Sony KV-35S26 35" TV
I have a Mitsubishi CS-40509 TV. It is over 12 years old. Recently, there is at least a 30 second delay before the tv responds to the remote control/control panel commands. If i turn it on, the green light...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then few TVs ( not all TVs ) behaves exactly as you have described.............. .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]] ---- in your case this transistor is good ... because when this component gets deffective then TV won't get '' ON '' .............so in your case only EHT should be replaced.........100% it works normally ----- though it is 12yrs old itseems TV TUBE is still in good condition because you have said that when display comes picture is clear......so if EHT ( same type) is replaced then your TV will work atleast for 2 more years.....GUARANTEE.......
May 22, 2011 | Mitsubishi Televison & Video
Samsung TXN3275HF 32" TV wont
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ...'' grrrrrr '' like noise comes ---no picture , no sound - (in case if picture & audio comes also it won't stay for much time) that noise is from EHT .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer ------- because they are highly experienced & can fix this component very easily. ------------ [[ sometimes along with EHT another component called transistor ( big in size - situated close to EHT - it will have 3pins - its size will be 1inch X 1/2 inch X 1/2 cm --approximately ---- black in colour ----- fixed to aluminium metal ) --- will also gets deffective --- so this component also should be checked ]]
May 10, 2011 | Samsung TXN3275HF 32" TV
The picture keeps on changing size.Can I fix this easily?
Hello, I need some more details so I can help, whether the image has grown in height or width? Or that the picture has grown at once, even height and width together? In addition I need the TV model, it says on the sticker at the back of the TV.
Feb 27, 2011 | Sony Televison & Video
My Thomson Tv quadra 21 inches nicam digital sterio purchased in chennai india is not responding to color, contrast adjustment, technician says memory is lost in chip and if the code is known memory can be...
Hello
It is not the code problem. There is only one code, and it is for adjusting its parameters , and have beed done at the factory, and havenot, and should not be changed at all. You just inform them to check its chroma section, with its schematic dagram nearby him, whether the colour and contrast pin control voltage of the chroma IC is vaiying according to the increase or decrese to the parameters with its remote or with its fron panel control. If it does not varies, tell him to check its system control side. OK
Feb 03, 2011 | Televison & Video
Our set was purchased in 2001. In the last month we've seen a narrow band (2") of parallel, "rippling" lines appear horizontally across the screen, just above mid screen. At first they...
Hello
You are saying about vertical retrace lines. Thes lines will be thin and spread all over the screen at about 1 inch aprat or so, little slanted in position. There are mainly two reasons for this fault. One is vertical output Ic and its supply related. Second is related with increase in screen voltage.
You just open your TV,and adjust the screen voltage a little less, by the help of screen voltage adjuster reistor. It can be located on the picture tube base card, diretly soldered to it. If it helps no need to do anything. After adjusting the scren voltage, increse the brightness contol a little and see whether the lines are there or not. If not it is ok. If yes, you have to go to the vertical output section of your tv. Any screen voltage adjustment should be done after decresing the brightness, contrast and colour controls to its minimum. At this condition you will only see the display items only. Screen voltage is so much related to picture clarity. It must be done in a dark circustace.
If it doesn't help, that is even after the lines are there when you increase the brightness, locate the vertical output section of your TV. It will be normally on the main board, and there will be an ic for amplifying vertical sweep signals. If its supply voltage has some trouble, this type of fault may occur. As your Tv is abot ten years of age, it is quite natural, that most of the capacitors has gone value detained. It is best for you to change all the capacitors, at about 14 nos of them at the same time, as it will cost not much. Change all the capacitors around the vertical output ic is best, as you can't measure the exact value of capacitors, without a capacitance measuring meter. Also look for any bad, or loose soldering is ther to the pins of the vertical Ic. Resolder all the points around and with it by applying a little more solder. This will retify your problem. Ok
Nov 09, 2010 | Sony KV-27FS16 27" TV
Thomson 21DC320 21" TV Logo
1,353 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
