Question about Holmes Products Heating & Cooling
Holmes HBH-5010 too hot
On low setting the heater does not stop running and is continuously heating and runs too hot
Therinnaiguy
  • 1420 Answers
SOURCE: holmes bh3955 or holmes hh3690
Depending where you live, here in Vermont we take square footage and multiply by 30 for a rule-of-thumb calculation. This gives us a very conservitive Btu rating. New York City use 20 Btu per square foot and Washington D.C. use 15.
Posted on Dec 07, 2007
  • 261 Answers
SOURCE: 98 dodge dakota slt 318. no heat, low operating temp
First thing first, turn off the engine wait for 15 - 20 mints, open the radiator cap and fill it up to the top then start the engine and see if it needs more water adn add as needed, then wait till you ca see the water circulating in the radiator now instead of corculating if it starts boiling out shut the engine replace the thermostat and do the whole thing again.
unless there is water in the engine the gauge will not be able to show the actual temp of the engine, so always malke sure you have water / antifreeze
Posted on Nov 15, 2008
  • 70 Answers
SOURCE: Heater running continuously
Sounds like you have a problem with your heat pump. Your aux heat is a electric coil. how old is the unit when was the last time it was serviced? How cold is it out side?
Posted on Jan 16, 2009
  • 48 Answers
SOURCE: Heater fan only works on the two low settings.
if you have checked the switch as recommended, it is most likely to be the heater resistor which contols the diffrerent speeds. it is
normally fited near to the motor and is a squarish block with multiplug on it and coils like springs in the centre of it, look at the coils they may be burnt out.hope this helps
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: h100id induced pool heater runs for 4 minutes then stops heating
I just solved this about an hour ago. It's the connection from the circuit board to the ignitor. The same thing happened to me that it ran a long time and then it wouldn't. At some point it loses spark. The large wire from the board to thee= ignitor is the culprit. Take the ignitor out and press the two electrodes to about 1/4"-3/8max. Clean the surface plate where it meets the heater and also clean the brass piece on the othe end. Then clean the brass piece on the circuit board. Slide the 2 boots down a little and expose the receptacles. Press them a little with pliers, put them on their respective connections and then slide the boots back on. It started right up and has been running since! This after I bought a new gas valve $178! Let me know if this does it for you.
Posted on Aug 08, 2009
HCH6150 heater runs for a bit and then just stops
Open it up and clean with an air can, most common cause is due to overheating.
Dec 17, 2011 | Holmes Products HCH6150-U Ceramic Compact...
My new heating system is very noisy. When the system is switched on the the water makes a continual trickling noise as it runs down the pipes from the cylinder above to the boiler below and only stops when...
okay could be a slight blockage in the pipe did he do a hot and cold flush on the system ? pump speed could be too high or low or they could be air lock in the system ,
Sep 04, 2010 | Desa International CBN30T Central Heating...
Heater wont run on hi and doesn't get warm at all
One of two things here. You blew an internal fuse or the heating element is broken. Take your unit apart and check for bad fuses and also check that the heating coil has continuity. Let me know how you make out.
hardrocko
Feb 07, 2010 | Holmes Products HFH5606-U Compact Heater
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Rediant Hot Water Heater Won't Shut Off!
I've got the same problem this morning, any helpers out there?
Jan 25, 2008 | Rival Holmes Products / Mfg Prh6 Radiant...
Heating & Cooling Logo
49 people viewed this question
Top Holmes Products Heating & Cooling Experts
paulcarew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
