Question about Seagate Computers & Internet
HOW DO I FIX MY SEAGATE EXTERNAL DRIVE ?
SEAGATE bk EXTERNAL DRIVE bk
  • 8 Answers
SOURCE: seagate HDD external drive
set its jumpher ot the slave position and plug it on ide2/secondary port of the motherboard and dected it from bios setting of the pc which appears when u press delet/f2 buttin when computer starts.
Posted on Oct 08, 2008
  • 92 Answers
SOURCE: Seagate,external, Hard drive,160GB,knocked over,doesnt work
Buy a new drive. The beeps are coming from the hard drive and they say I'm broken. If you need to recover data, and only if you need it like life and death because it will cost a bit, send it to a data recovery company. I would search on line and look for somebody local to you for this if you need it.
As for your old drive, if you like to tinker, you may be able to remove the drive from the case and replace it with a similar sized drive with a matching interface (ide or sata). I personally like to remove the rare earth magnets from bad drives to make refrigerator magnets and toss the aluminum housing into the metal recycling barrel. It also ensure personal data is never coming off those platters.
Posted on Aug 09, 2009
  • 28 Answers
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
Posted on Sep 14, 2009
cowboytech
  • 69 Answers
SOURCE: Seagate 9SF2A4-500 external hard drive on Windows 98
Windows 98 will not run a drive that large, so that is your problem. You will need to connect it to a newer system, and break it down into small drives by setting up different partitions. Perhaps it will see it then. Also, most manufacturers are no longer supporting Windows 98. You really need to just upgrade your system to a newer OS.
Posted on Feb 13, 2010
lock123
  • 6831 Answers
SOURCE: Dead Seagate external hard drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Using Seagate Goflex Hard-drive 750 GB, upgraded Windows 7 to Windows 10. get message Seagate harddrive not supported on Windows 10. Is there a solution to fix this? Russ
Will My Hard Drive Work With Windows 10? - PC Magazine
www.pcmag.com > ... > Windows 10
PC MagazineJul 29, 2015 - Some drive manufacturers have gone through the Windows 10certification process, ... Seagate products are NOT compatible with Windows 10.
Seagate GoFlex not compatible with Windows 10 - Microsoft Community
answers.microsoft.com/.../windows/.../windows_10-hardware/seagate...n...
Aug 4, 2015 - Since, the Seagate Dashboard is not compatible with Windows 10, let's try ... 10 with my Seagate FreeAgent Go Flex Home 1T external hard drive - model ... Windows 10 Backup Not recognizing Seagate Desk External Drive ...
Aug 18, 2015
Windows 10 Install- Now Seagate External USB 3TB HardDrive ...
Aug 13, 2015
Seagate 3TB external hard disk not working with Windows 8 ...
Jan 26, 2013
More results from answers.microsoft.com
Dec 16, 2015 | Seagate Computers & Internet
Fix my old seagate external drive
remove the external cover and connect to PC internal drive controller and scan by partition recovery software and fix it.
if contain partitions and drive letter showing on the my computer right click and select properties select scan now with check box in tools tab
Dec 09, 2015 | Seagate Computers & Internet
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
Access denied on an external harddrive.
quick fix is to format the hard drive.. otherwise you'll have to get your data back with a seperate program...
Jun 01, 2009 | Seagate FreeAgent Pro 500GB External USB...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500gb Free Agent Ex Hard Drive - Class Action siut
DO NOT buy a Seagate freeagent drive under any condition if it comes as a gift return it or re-gift to some one you don't like. Like so many others my 500GB external drive just quit working. Has only been plugged in about 6 times and then back into a cabinet to keep safe. In 10 years between 2 workstations 3 laptops and 4 external drives. The only drives that have ever gone bad are the Seagates and newer Maxators. I still have 4 Western digital drives that still work and get used in an external case for back up. They have never failed. Seagate should be responsible for data time and mental anguish.
Jan 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
