Question about Whirlpool MH7140XF Microwave Oven
Whirlpool microwave model mh7140xf mh7100xy
REPLACE FUSE
  • 57 Answers
SOURCE: No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Posted on Oct 01, 2007
dmftrucker
  • 1922 Answers
SOURCE: How do I replace the fuse or reset the circuit on
remove the outer cover and its in a fuse holder on the right side of unit get the right amperage
Posted on Oct 05, 2009
  • 254 Answers
SOURCE: have an older model (RM278BXV) Whirlpool microwave
what is the problem with it im guessing it prob doesnt heat, if so prob need to get acess inside and check components i would recommend getting a service call as some componoents inside are still live even when unplugged,, it might require a magnetron which would be fairly expensive but if u dont wana replace it than i guess its your only option.. hope this helps
Posted on Feb 07, 2010
jsrock516
  • 5911 Answers
SOURCE: broken handle on whirlpool model MH7140XF
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is available at appliancepartspros.com. There are several part numbers listed, based on the color of your oven, so make sure you order the correct handle. Here is the parts listing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=93877#d93877
If you have any questions, please post back and let me know. I hope this helps you
Posted on Apr 13, 2010
  • 6771 Answers
SOURCE: Own Whirlpool microwave model MH7100XY,
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Posted on Mar 19, 2011
Whirlpool mivrowave W10292071A MH7140XF Microwave Oven
My whirlpool microwave hasn't worked sice powers outage. Is there usually a reset button or fuse, somewhere
Jan 03, 2013 | Whirlpool MH7140XF Microwave Oven
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
The microwave displays F-6 and won't stop unless it's unplugged. Needless to say, it can't be used.
F6
Shorted temperature probe
This code will occur if temp. probe is detected as shorted
continuously over 5 seconds.
Replace temperature probe. part no 29 Thermostat
Part Number: AP3038826 made by WHIRLPOOL
The above part and all other parts of your model can be foundin the link
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260444&diagram_id=28263369#d28263369
Jan 01, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 15, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave died
your microwaves internal ceramic safety fuse is blown most hdwg stores carry them they're a 15 or 20 amp fuse,dont replace w/any other type of fuse,but first find out why oven blew the fuse
Aug 13, 2009 | Whirlpool MH7140XF Microwave Oven
Outlet works but the microwave is dead, no power at all.
I had a similar problem with my Whirlpool microwave. I replaced a fuse (after reading posts in this forum) and it's working again.  I'm not sure how similar your model is, but in my case it was an in-line fuse in a wire leading down from the main fuse in the upper right corner behind the control panel.
Apr 04, 2009 | Whirlpool MH7140XF Microwave Oven
No power on microwave
Buy a new one. Microwaves have enough stored voltage/amperage to boil your blood. You should not be taking off the cover.
Mar 07, 2009 | Whirlpool MH7140XF Microwave Oven
I need User Manual for my microwave
Just click below;
Whirlpool Microwave/Hood Combination manuals, user manuals, owners ...
Whirlpool Microwave Hood Combination MH7140XF, YMH7140XF User Guide Get This Manual .... Please help find the manual for this Black & Decker Convection Oven ...
Hope this may help you; DON'T FORGET TO RATE:
Sep 06, 2008 | Whirlpool MH7140XF Microwave Oven
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
