Question about Top Paw Extra-Wide Metal Walk Through Pet Gate
How do I assemble a Top Paw Extra Wide Walk-Through Pet Gate?
I bought a Top Paw Extra-Wide Metal Walk Through Gate which looks perfect for my needs, but there were no assembly instructions. Can you tell me how to assemble it, please?
Need spindle and hand wheel for gate. bought at a yard sale and it is missing one.
We do not have parts. We just answer questions.
Try Googling the manufacturer, maybe they have replacement parts.
Apr 19, 2015 | Top Paw Extra Tall Pet Gate with Small Pet...
Is it possible to get spindle and hand wheel replacement parts. bought at a garage sale and missing one.
We do monitor, but we are not a parts supply place.
You have not even mentioned the brand.
Google the manufacturer to contact for parts.
Top paw extra wide gate
Contact customerservice@carlsonpet.com or 952-435-1084. Top Paw Extra Tall Pet Gate with Small pet Door item: 10957722, UPC: 73725727486. Replacement hardware kit includes four spindle rods, four wall mounts and four mounting screws.
Jun 10, 2014 | Top Paw Extra Tall Pet Gate with Small Pet...
Where can i get the end part that screws into the wall?
here is the phone number Carlson Pet Products 952-435-1084.
Mar 28, 2014 | Top Paw Extra Tall Pet Gate with Small Pet...
Need replacement parts for tall pet gate
I have the same gate and have the paper work that came with it.
Top Paw is Carlson Pet Products, Inc. Their # is 952-435-1084
Dec 01, 2013 | Top Paw Extra Tall Pet Gate with Small Pet...
I need the same, but this is the best I can find but not sure if will do the trick for the Top Paw tall gate I have. Did you find a solution? http://www.gates4pets.com/bindaboo-pet-gates/gate-accessories/replacement-hardware-parts-for-gates-white.html
Assembly guide for larin rear cargo carrier model # CC-500
1) do NOT tighten nuts as you assemble. Loosely finger tighten to keep bolts in place during assembly.
Tools: adjustable wrench, ratchet, quick release clamp, linesman pliers.
2) think about a zipper closure, start at one extreme end point and work top side bolt hole, bottom side bolt hole, next bottom bolt hole, middle bottom bolt hole, etc. I suspect the factory measurements are slightly off, so the holes are not aligned perfectly. Using the clamp to slightly bend the metal helps align the first outer bolt hole and gets the rest of the holes lined up.
3) can be done as a 1 person job, I suggest having an extra set of hands for holding carriage bolt heads still while tightening. Also for lifting, extra set of eyes to ensure cage parts are aligned correctly, and helping you keep your patience.
4) place entire assembly on the trailer hitch, test you rear gate/ door movement, and spacing in the garage.
5) if you decide you would like to keep the device, go ahead and finish tightening the bolts with wrenches, opening and closing the cage as needed, to keep carriage bolts in place. (This is where extra set of hands will help out again.)
i just finished assembling this myself and had to draw on 20 yeas of experience with assembling poorly aligned objects. I had to walk away once or twice to calm down before I stripped or bent one of the bolts.
I could not not find any helpful hints on any sites or YouTube channels. I hope you find this helpful with your assembly project.
May 02, 2013 | Larin Academy Sports Rear Cargo Carrier
Need bolts for pet gate
If you get a response, would you please email me at mwiles@mauryregional.com. I'm having no luck anywhere and need 4.
Apr 20, 2013 | Top Paw Extra Tall Pet Gate with Small Pet...
Top Paw Extra-Wide Metal Walk Through Pet Gate Logo
135 people viewed this question
Top Top Paw Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Top Paw Baby Gear Expert? Answer questions, earn points and help others
