Question about HP Officejet 5610 All-In-One InkJet Printer
Can't Print on Card
I bought this printer about a year ago and until a couple of months ago, worked completely well on all printing surfaces. Now I can't print on any type of paper heavier than normal printing paper. Help! I really need to print on card!
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Posted on Oct 15, 2008
SOURCE:
I just bought a brand new printer a couple months ago. It recently started only printing every other or every couple lines of print. If I type up a letter it will print one line and then skip a line. ...
Do a head cleaning at least 3 times and then print a test page and see what you get. Also in printer settings see if you are on "Default" or you changed it somehow........
Nov 26, 2013 | Epson WorkForce WF-2540 All-in-One Inkjet...
I have had my Epson R1900 since last July, and it has worked just fine for me up until a couple of months ago when it began printing with a very noticeable blue-green tint. I always use Epson 87 inks, and...
using your printer once a week makes your printer clog even if you use original cartridges i prefer using it once a day, if you dont have anything to print, just turn on your printer and it will automatically head cleaned its head
May 24, 2011 | Epson R1900 Printer
Can the ink dry up. installed printer ink a couple of months ago but will not print now. printer prints blank pages.
hi!
yes ink can dry up.. big chance your ink have dried up, since you've installed them couple of months ago.. there's a possibility that the ink may have not dried up but the print head may clogged.. you can try running some maintenance like clean cartridge or print head test using Dell All inOne Solution center..
Hope this helps..
Sep 11, 2010 | Dell V313w AllInOne InkJet Printer
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
The printer does not print when commanded
try and copy something and check if that comes out blank or not..........if it comes out fine then just follow the troubleshooting guide on www.kodak.com/go/itg .
Dec 23, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
BJC 4550
chech if the ink cartrades are plugged in tight in they are check if all the chords are plugged in if that doesnt work go to a tech man or get a new printer
Jul 08, 2007 | Canon BubbleJet i550 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
464 people viewed this question
Clive
Clive
Thomas F. Schneider
