Question about Kenmore Dishwashers
Kenmore bosch error code e20 - Kenmore Dishwashers
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: E20 error on Kenmore front loader. The water is
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Wfmc3200 run diagnostic and see e20 c01 and d10 c01 codes. Bad motor or something in the drum support?
    E20 error code: Short or break causing incorrect resistance in winding of the circulation pump or the motor.
    D10 error code: Cause: Wiring/electrical fault related to motor triac.
    Action: Check wiring on/to PCB and motor. Check the triac (on the PCB).
    C01 error code: Cause: Motor tacho fault.
    Action: Check motor and motor tacho wiring for problems.
    Apr 19, 2015 | Bosch Washing Machines
    Frigidaire front load washer (ATF6000SF1) error E20
    E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
    1. Restriction in the drain pump
    2. Failed pump
    3. Water not pumping out fast enough (crimped drain hose)
    4. Too many suds ( too much detergent or wrong kind)
    5. Pressure switch (not communicating with control board)
    6. Loose wire at pressure switch
    7. Loose wire at pump or control board
    8. Failed control board
    Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
    I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
    The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
    Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
    Aug 20, 2011 | Washing Machines
    My kenmore he washer will not drain all the water also have code E20 flashing
    2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
    3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
    Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
    Bosch Washer WFMC3200.
    first of all, start with you close the door,you put the set on and continue please
    Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
    Jun 07, 2009 | Kenmore 44072 Front Load Washer
    Dishwashers Logo
    21 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
