Question about GE GFSS6KKYSS
Loud humming and ice maker not working - GE GFSS6KKYSS
5 Suggested Answers
SOURCE: Humming sound from GE side by side regrigerator ice-maker
condenser freezing up
Posted on May 10, 2009
  • 106 Answers
SOURCE: loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Posted on Mar 29, 2010
heatman101
  • 43501 Answers
SOURCE: ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
nm.nbydg
Posted on Sep 30, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have a GE side
Sorry to read about your problem, I hope this helps you out.
it maybe your fan, going bad. or you have a ice build up, and its hitting the fan..if this is the case, you have a defrost issue. or a bad fan.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
I have a GE side by side refrigerator with ice maker. Refrigerator has been fine and now it just started making a loud like humming noise which is coming from the freezer the ice maker works when I open...
3 Thumbs - Helpful
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Amana DRS2660B Side by Side Refrigerator
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Periodically throughout the day there is a loud motor noise.
you may have a fan problem or ice maker open freezer switch on the frame freezer side press it you will know were the noise comming from
Apr 06, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
GE GFSS6KKYSS Logo
75 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
