Question about Hitachi LifeStudio Computers & Internet
Can i use my hitachi lifestudio as a second external hard drive
lock123
  • 6831 Answers
SOURCE: Hitachi External hard drive 500GB doesnt turn on
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 240 Answers
SOURCE: can not burn movies to my Hitachi 1tb external hard drive
I copy and paste the movie file just like you would do from one folder to another,it takes a few minutes sometimes but worth it. You can cut and paste but I don't recommend it as if anything goes wrong you could lose the original.
Posted on Dec 03, 2011
SOURCE: Hello I cannot transfer files from my hitachi lifestudio to my desktop or to another hard drive. It seems to copy all files except movies?
are those movies large(most likely) might be that your usb is overloaded suggest you consider using ethernet or other high volume connection
Posted on Jun 07, 2012
Geekman
  • 32281 Answers
SOURCE: Computer won't recognize external hard drive anymore Hitachi lifestudio
Try connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Posted on Jun 08, 2012
Geekman
  • 32281 Answers
SOURCE: I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
I lost the softwear, how do i get a download of it for the hitachi lifestudio ?
More than likely the software is available at Hitachi's website, so check there or give them a call if you cannot find it through the website. They may be able to email the software to you or provide the link by email. If the software is licensed in some fashion, they may ask for the serial number of your external hard drive, so you might want to have that handy just in case.
Sep 23, 2014 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
Clicking noise
Backup it immediately if you want your files. The next step is a total faillure of HD
Oct 20, 2013 | Hitachi 35IN LIFESTUDIO DESKTOP 1TB...
Power supply specs Hitachi Lifestudio Desk Plus
Hitachi Lifestudio Desk Plus Hlsdpub10001bbb 1TB Drive and original AC adapter have been separated. Need to know Adapter output Voltage/amperage identify original or acceptable replacement.
Sep 17, 2013 | Hitachi Lifestudio Desk Plus...
Hitachi lifestudio hangup or comesout during middle
sorry but I am not understanding what your problem is please be more specific
Feb 23, 2013 | Hitachi 1TB LifeStudio 35 Desk Plus...
Jun 07, 2012 | Hitachi 35IN LIFESTUDIO DESKTOP 2TB...
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Lifestudio isn't installed on my pc anymore and when i plug in the external hdd a light comes on but nothing happens
1. From what I read it may be the port drivers that are not installing for the USB port you have connected you hard drive to.
2. Check the manufacturers site for driver updates and hard drive requirements
3. It may be that the driver are not for the OS that you have or you may have to download them.
4. Try another cable ( USB)
5. Last it may be the internal electronics of the drive itself that may not be writing or reading the information sent by the pc to the port .
You may need a new case with new electronics ( hard drive main board).
Oct 12, 2011 | Hitachi 35IN LIFESTUDIO DESKTOP 1TB...
I'M LOOKING FOR A HANDBOOK FOR THE HITACHI LIFESTUDIO EXTERNAL HARD DRIVE
I went to Hitachi and found there are no comprehensive downloads for the Lifestudio. There is a fact sheet (http://www.hitachigst.com/tech/techlib.nsf/techdocs/68DD13D427A74F528825774A0067913B/$file/LifeStudioMobile_datasheet.pdf) and some movies(http://www.hitachigst.com/tech/techlib.nsf/products/LifeStudio_Desk)
Sorry there doenn't seem to be more information. Hope this is useful:)
Aug 24, 2010 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
