Deep freeze removal
How to remove deep freeze 6, (bypassing the password)
    Sergeant:
  • 186 Answers
You need Deep Feeze removal. Ask google for the same.
Posted on May 19, 2009
I forget my deep freeze password
Here is a site to start...I'm looking for more... SecuriTeam™ - Deep Freeze Unfreezer - Bypassing Deep Freeze Authentication BE SURE TO READ THE FEEDBACK SECTION AT THE BOTTOM OF THE PAGE to get the latest remedy...found at this URL... Deep Freeze Unfreezer ! And be sure to check out... Deep Freeze Unfreezer This is his startup page.
Dec 18, 2010 | Computers & Internet
Yahoo.comHow to uninstall deep freeze 6 software from PC
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password. 1. Boot yr PC from the CD with windows XP, if u have Windows XP OS 2. Now enter R to repair after booting. 3. Let it continue until finish 4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
Aug 25, 2010 | Computers & Internet
Remove deep freeze from computer
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 19, 2010 | Computers & Internet
How to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
How to uninstall deep freeze 6 and where to find the files to delete
hi
Note: I tested this method on Windows XP only, on another windows version maybe this method does not work.
Jun 27, 2010 | Dell Computers & Internet
How to disable deep freeze without a password
How to Uninstall Deep Freeze for Windows 2000/XP/Vista without the password.
Note: Without a complete uninstallation you may not be able to reinstall Deep Freeze on your system.
What we are going to do is edit the registry and delete the startup references to Deep Freeze. This will prevent the Deep Freeze driver from starting up the next time you boot. (c:\windows\system32\drivers\deepfrz.sys)
1. First we need a way to edit the registry. The way to do this depends on your situation. If your computer is thawed you can simply use Regedit. If your computer is frozen or if it doesn't boot you'll need to find another way. Here are some alternatives:
If you have a multiboot computer with another copy of Windows 2K/XP you can boot from there. Or, you can physically mount the disk on another computer that uses Windows 2K/XP.
You will probably use a tool that lets you boot and edit the registry. A good example of this is PE Builder that lets you build a Windows PE CD and boot Windows from there. Or use Bart's, http://www.nu2.nu/pebuilder/ or Winternals ERD Commander. There are several, including some USB memory sticks capable of booting like a CD. The goal here is to boot separately from your hard drive and access it while it is "asleep".
2. If your computer is thawed run Regedit. If it's not thawed follow one of the alternatives described above, and run Regedit (or Regedt32 on Windows 2K).
3. On the Find dialog box type UpperFilters and check only the Values checkbox. Then click Find Next.
4. The program will find a value with the name UpperFilters. Open this value and if there's a line with the name of the Deep Freeze driver (DeepFrz or DepFrzLo) delete it including the return, leaving the rest of the lines intact. Also, if you are using ThawSpace and you want to get rid of it delete that line too (ThwSpace), if you want to keep the ThawSpace leave it there. Press F3 to find the next match and repeat the operation until you have fixed all the UpperFilters values inside the HKLM\MySystem key.
5. Navigate to HKLM\MySystem\Select and check the value with the name Default. It has the number of the control set key that the system will use when booted. If it is 1 the control set is ControlSet001, if it is 2 the control set is ControlSet002, and so on. We'll assume the control set is ControlSet001 but you should use the one specified by the value Default.
6. Now go to HKLM\MySystem\ControlSet001\Services and delete the keys with the name of the Deep Freeze drivers (DeepFrz or DepFrzLo and DepFrzHi). Also, if you decided to get rid of the ThawSpace delete the key with the name of the ThawSpace driver (ThwSpace).
7. That's it. Now reboot and Deep Freeze will not load.
QUESTION: What if the BIOS settings prevent me from booting from CD or USB? Answer: Deep Freeze prevents you from decrypting the BIOS password, but it does not prevent removing it, if you have the right tool! Most of the BIOS hacking programs will not work to remove the BIOS password on a Deep Freeze protected computer, but CmosPwd by Christophe Grenier does.
You'll need to know how to use a command line and install the driver. Yes, it uses a driver to remove the BIOS password. But it works, even on Deep Freeze protected computers. Use CmosPwd to remove the BIOS password and reset the default BIOS settings. Then you'll be able to boot from CD or USB and edit your computer's registry and remove the DeepFrz, DepFrzLo, and DepFrzHi references which start Deep Freeze.
Now here is a little known secret: Faronics (the makers of Deep Freeze) uses a special driver to remove broken or malicious Deep Freeze installations. They do not have any backdoor passwords, so they use a special driver to remove a Deep Freeze installation where the password is not known or that someone is having trouble with. Will they send it to you, or even admit to you that they have it? I don't know. But, even if you do have it, you will still have to boot separately from the hard drive and replace the existing Deep Freeze driver with the special one and reboot. And after that, you need to use a Deep Freeze installation file to fully uninstall Deep Freeze (it will be thawed when you boot up with the special driver). If you want to re-install Deep Freeze, you'll have to first delete the special driver too.
Only a few people have this driver. It is the only solution Faronics has for those who need to remove Deep Freeze without the password. And, like I said, you will have to be able to boot from CD or USB and access the NTFS hard drive. If the boot-up order is locked (hard drive first and only) in BIOS settings, use CmosPwd to reset BIOS and boot order. Then you can boot from CD or USB.
Booting from CD or USB and removing the registry references works also, but then you should uninstall Deep Freeze with an installation file once you are able to boot thawed.
If you are dealing with a trial version of Deep Freeze, just forward the BIOS date past 60 days and then restart.
If anyone is wondering if Deep Freeze has ever been hacked, the answer is "yes" it has, several times over the years. Most of the time these were weaknesses that Faronics was able to quickly fix or prevent. However, there was one hacker that really, REALLY gave them headaches. His name was Emiiano Scavuzzo from Argentina. He was really good at low level programming and used OllyDbg to come up with about five versions of his "Deep Unfreezer" which gave Faronics their greatest challenge to date. Deep Unfreezer now only works on older versions of Deep Freeze.
Faronics is doing very, very well right now (as of 2008). They sold Apple Computer their Mac version of Deep Freeze, which, if you know how to look for it in the Applications folder on a Mac, is used in all the Apple Stores on both their desktops and their laptops. So, if you're ever in a Mac store playing around with PhotoBooth or whatever, and the computer settings are all messed up, just restart the Mac and thank Deep Freeze.
Apr 11, 2010 | Computers & Internet
How to remove deep freeze from computer srinu K
You have to go to your computers boot menu and boot into deep freeze menu and you must have the password. If you do not have that password you will need to completely re-install your operating system. You can also access the deep freeze menu from within windows but again you have to have the password
Mar 17, 2010 | Computers & Internet
I cant remove the deep freeze software standred 6
read this :
http://www.faronics.com/faq/default.asp#7
1-This software (protection) is effective, it is
impossible to ignore, unless you remember
password entered at the first reboot after
installation password that allows you to unfreeze
the position, necessary step prior to
uninstallation. To access the password window
Password combine the ALT + CTRL + SHIFT + F6, then
choose "boot Thawed" and restart.
2-for Windows 2000 or XP
Go to Start-> Control Panel-> Tools
Administration-> Services
click on right click then Properties DFServEx
in the general tab in Startup type: select
Option deactivated
then reboot and all will be resolved
3-http: / / www.faronics.com/
4-for disabled deepfreez is simple
pressed the button shift + double click on deepfreeze
nearby clock. enter the code if you enter the / if you did
not click OK.ENSUITE CLICK ON BUTTON LE3EME
ENSUISTE OK and restart THE PC
after the boot up you found approximately one thinks red
deepfreeze ok
releancer installing deepfreeze and its SETUP
you found approximately UNANSTALL OK UNTIL THE END
AFTER rebooting TT WILL BE AS BEFORE
5-download the recent version of deep freeze and
installation and during installation it asks you
uninstall the previous version and continues to validate
jusqau he asks you to install the new version
cancel
Sep 09, 2009 | Computers & Internet
How to uninstall deep freeze from your pc?
To uninstall:
Apr 08, 2008 | Computers & Internet
Deep freeze
hi.. ! i am working in internet cafe , from yestarday hotmail is not working they say you have to install new version of windows massenger. i can install the new version of windows live .but i have deep freeze in my every computer.but i can't see the deep freze icone in my textbar its show but when i go to put mouce corser its desapiar i wnat to disable the depfreze .pliz help me any one.. what sholud i do ..? and when i try to reinstall the deep freez then computer says " disable first the allraday insatall deep frezz , pliz help me. thanx.
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
397 people viewed this question
David Payne
David Payne
