Question about HP DeskJet Office Equipment & Supplies
HP deskjet 3526 will print color but not black. all new ink
5 Suggested Answers
wayneard
  • 1901 Answers
SOURCE: hp deskjet 3845 won't print in color
When you click on "Print" and the window comes up, click on "Preferences".
Click on the "Color" tab. There should be an option to print in color or grayscale. Select "Color".
Posted on Oct 18, 2008
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
cene765
  • 787 Answers
SOURCE: HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Posted on Oct 13, 2009
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
Jan 16, 2010 | Apple HP DeskJet 840c InkJet Printer
I tried to print a photo card on my hp deskjet
yes, both cartridges are used for all print jobs, color or not.
Jun 14, 2009 | Office Equipment & Supplies
HP Printer Deskjet 697C won't print color
Unfortunately when a inkjet printer is not used in a while the ink dries up... If I was you I would try a new color cartridge and see if that helps out. It is a fine balance with ink jet printers... you don't want to print so much because ink is expensive but you want to print enough to keep the heads and ink from drying out. Good Luck!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | Office Equipment & Supplies
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
My printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Nov 11, 2008 | HP DeskJet 812c InkJet Printer
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
579 people viewed this question
Seeker5211
Seeker5211
