Question about Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder
I have pulled the tv apart to put it in a new tv unit, now foxtel wont work and im not sure how to plug all the cables back together. has no signal
    President:
  • 814 Answers
You should be able to the the information you need in the owners manuals of your products. If you do have the manuals, go on line to the websites of you products and check them for the owners manuals. The websites usually have copies of the owners manuals for people who did not get one with their product or lost theirs.If you still are having a problem with the connections, contact the support technical service for the products for help with your problem. I hope this helps you with your problem.
Posted on May 19, 2009
Can't get a picture on our free to air TV set it keeps coming up no signal, we have a picture and sound on foxtel
you may find that the aerial inside your home was disconnected and used to wire up Foxtel in the roof, some technicians do that,
meaning all your Tv Outs on the wall would now be connected to Foxtel now instead of the aerial
if you can gain access to the junction of where all the Cable Coax wiring is in the roof make sure they haven't used the tv aerial cables for Foxtel ....just go check where your Aerial comes in and see it is still connected to the junction and not pulled out and a foxtel is going into it instead of the aerial
Apr 26, 2017 | Televison & Video
1986 25 hp johnson just removed lower unit put back together and now stuck in foward wont go into nutral or reverse
Check Srew Pivot Pin On Side Of Gear Box !
Sounds Like It Has Missed The Shift Cam Pivot Point
You Should Be Able To See The Whole That The Pin Should Go Into
When It Is Lying on Its Side
Mar 16, 2013 | Boating
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and...
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 27, 2011 | Toshiba 47LZ196 47 in. HDTV LCD Television
Tv picture is totally white, has sound
The tv Tuner signal board it the problems and the causes.That the board,where the tv incomming broadcasting signal cable wire plug into it.U can take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Mar 21, 2011 | Sylvania 6626LCT 26 in. LCD Television
Rca switch on work good for 1 hr and get black screen with audio
The tv Tuner signal board it is the causes and problems.Because ur tv are intermitently shutdown after an hour of used.Mean the tv Tuner sisgnal board have some kind short in it circuitries,could be anythings,components parts wise.The tv Tuner signal board,that the board where the incomming broadcasting signal cable plug into it.U have some skills,like u can take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Mar 01, 2011 | RCA 47LA55RS 47 in. LCD TV
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
I need to know if I put it back together right
If you pulled it apart and put it back together but now it won't work properly, try checking your IDE cables to the hard drive/cd-rom, make sure they aren't connected backwards. Otherwise just carefully look over the entire board, be sure that the processor, heat sink and fan assembly are all intact and connected properly, do the same with the RAM, power connection, any expansion cards.
May 06, 2009 | Computers & Internet
Connect my 6920 to tv or through foxtel
Hi the 6920 may have a HDMI out(mine does) if not Maplin are selling a PC to TV box, it converts VGA to AV signal (£30) hope this helps
Feb 21, 2009 | Acer Aspire 6920 Notebook PC
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
Panasonic DMR-EX85EB-S DVD Recorder/HDD Recorder Logo
105 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
