Question about HP DesignJet 90 - printer - color - ink-jet InkJet
System error 070100 00AD030D
WHEN I START PLOTTER THEN IT SHOWS SYSTEM ERROR
070100 00AD030D AND GIVES THE OPTION TO PRESS ENTER TO CONTINUE
SOURCE: ERROR CODE 04C400 - WHAT TO DO, WHAT IS IT
Pulled Harddrive and ethernet card, no error. Installed hard drive started machine, no error. Installed ethernet card, restarted machine got error. I am now replacing the ethernet card to resolve issue.
Posted on Jun 24, 2008
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
efs_perpends
  • 1996 Answers
SOURCE: What is the matter with "calibration error (1042)" in plotter?
HP actually recommends that you contact them directly when you get this type of error message.
I can provide a link for you to access their troubleshooting online, at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=82218&prodTypeId=18972&prodSeriesId=82218&objectID=bpp02995
where you can click on the contact HP link in calibration errors to receive further assistance.
Here's that link:
Click here for information on contacting HP support at http://h20000.www2.hp.com/bizsupport/TechSupport/CallHP.jsp?locale=en_US&docIndexId=179680&taskId=101&prodTypeId=18972&prodSeriesId=25301.
If that doesn't interest you, you can browse the HP support forums, and you will find other examples of printers like yours with the same or similar errors, and HP experts who guide them through the fix. http://forums13.itrc.hp.com/service/forums/bizsupport/categoryhome.do?prodSeriesId=82218&lang=en&prodTypeId=18972&categoryId=414&cc=us&admit=109447627+1238315749385+28353475
That's my best advice for a quick solution, to go straight to the source. After all, they have the most experience with these things...
If somehow I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Mar 29, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
Hi, I am using an HP Designjet 4520ps plotter and am getting error 84.16:01 - Possible paper jam. There is no jam, it occurs somewhere in the middle of a print job and renders the job a waste. Any...
84.16:01 is a BT arm failure.
In the diagnostics submenu, go to 2.2 BT Arm test. Press ENTER.
If you have a failure, The front panel will display System Error Code 01.0:10.
At this point call HP if you still have a warranty. Otherwise, call a trained DesignJet tech
Jun 13, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
Tip
Windows XP Repairing
XP is a windows based operating system. XP is client OS which file format is Fat32 and NTFS. Some time for user fault, unauthorised operation, improper shutdown, viruses or any other cause may corrupt this file system and it may crash your windows also. Formatting and reloading of windows can solve your problem easily. But maybe there formatting is not possible for important data or for product key. So there repair of OS is only way to recover.
I have facing almost the same problem once. There customer have a confidential file in his system's desktop. Desktop belongs in C: drive where the OS resides. First I tried to recover the data but nothing is possible there. Then I started to repair the Widows. I insert the XP CD in DVD-Rom drive boot from it. Start the windows setup after loading files it ask for a repair (R key) I have ignore it by pressing Enter then the license agreement screen appeared. Then the OS instruct to press F8 to agree with the license and continue setup. After pressing F8 it will find the previous version of OS, if setup found any previous version then it will give you option to repair the OS again. But that day I don't get this option. It shows total disk space of C: drive have remain free space. So that there was not any file to recover the OS.
Then I go to boot the system again but formatting is not possible so after loading files at the first while the first repairing option appeared I have accept this repairing option. This option is from dos repairing option. After pressing "R" while appear the dos screen. Then press Enter to continue. Then I run the command "chkdsk" in C: drive to check the disk. After complete the disk checking and fixing the error I reboot the system again. After that I have Boot the system and after completing the whole process I choose the second repairing option. Then I got the previous version of OS and start to repair the previous OS. It now just loads the file and get started XP after booting. I got success to repair the OS and recover the data.
So it is a secure and easy process of recovery.
on Mar 12, 2011 | Computers & Internet
We have a HP Designjet 4520ps plotter that is having the error message 79.04 According to HP this is a firmware error so we decided to try to update the firmware. We downloaded everything we could find...
dear sir/madam,
in this hp designjet 4520, this error comes up :error code 24:10. when i enter it, in the service manual it shows: Broken bag detected in Ink Cartridge. but it doesn
Mar 25, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
Does the HP DesignJet 1050c plotter have a counter?
This data is printed out on the Service Configuration Print
  1. Load the plotter with media.
  2. When the device is 'Ready' scroll the menu to the Printer setup options and press Enter.
  3. Once in the 'Printer Setup options' menu, use the arrow keys to scroll to 'Utilities', and press Enter.
  4. In the Utilities menu, use the Arrow key to scroll to 'Test Prints' and press Enter.
  5. Use the arrow key to scroll to 'Service Config' and press Enter to print the Service Configuration Print.
You should find the data you are after under the heading of Maintenance on the printout
Good Luck!
Dec 07, 2009 | HP DesignJet 1050c InkJet Printer
Error : em8tqm.cmd
may be it cause virus praveen
go to start button and click run
and type cmd
then type
cd\ and press enter
then type
attrib -r space -h space -s space autorun.inf then enter
ex: 1. attrib -r -h -s autorun.inf enter
2. del autorun,inf enter
after that go to d: and press enter
Apr 08, 2009 | Microsoft Windows XP Professional for PC
Cant do EEROM setup coz severe error:0x4010008 occured
restart the plotter in service mode using following method
1 power off the plotter
2 press Up Arrow + Enter Button ( green buton) and while pressing both buttons switch on the plotter
3 when u see service test /Service utilities release keys & select service utilities & then perform eerom setup there , put the actual model number ( c7780b/c ) and it wil resole the issue
Mar 30, 2009 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
Jun 23, 2008 | HP DesignJet 1050c InkJet Printer
Original setup was interrupted
press F8 key (just after BIOS screen) at the next cold reboot and you will see a DOS screen with 3 or more options. Read each of them and I think you will see one option is to resume setup. This option places the system at a safe entry point to continue the setup. Another option may read "cancel setup and restore previous system"...this one may be used if you cannot get the "resume setup" option after repeated tries.
Aug 03, 2007 | Compaq Evo N610C Notebook
HP DesignJet 90 - printer - color - ink-jet InkJet Logo
169 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
