Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Cassette does not. open - Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape is torn and I need to get it out of the cassette housing, splice the tape, then place in a new housing. Where can I get a repair kit??
Cat. No. 44-626 used to be available at Radio Shack but no more.
http://www.tracertek.com/new-cassette-tape-shells
This might work..
http://www.gearslutz.com/board/geekslutz-forum/31114-cassette-repair-kit.html
"Splice the broken end to the take up reel of a newly bought cassette that you can open.
open the new cassette,
trash the interior
If you can't move the old reels to the new mechanism:
tape one side of the broken cassette's tape to the new take up reel
close the new cassette (do not open or break the old cassette if it's not already done)
insert a pencil into the gizmo on the take up reel on the new cassette,
reel up the old cassettes tape into the new cassette
re open the new cassette
splice the other end to the new cassette's gizmo
record the contents to digital"
Feb 05, 2011 | Audio Players & Recorders
I have a duel cassette player sony model # TC-WR 565. The doors will not open and both casettes cannot be removed even after prying the door open.
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
Dec 29, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette compartment cover blocked
have you try to open it and see for any loose spring parts.?
thanks
Apr 23, 2008 | Cameras
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds.
Sep 04, 2005 | Canon Optura 400 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Cassette am
To unload the videocassette from the cassette compartment, the camcorder needs to be connected to a power source (either an electrical outlet or a charged battery). Please refer to the following instructions. Connect the camcorder to the power source or insert the fully charged battery pack, and then slide the EJECT switch to open the cassette compartment cover. The cassette compartment cover will open, and then the compartment will open automatically.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
16 people viewed this question
Top Sharp Video Cameras Experts
noel
noel
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
