Question about HP 5850 COLOR INJET PRINTER C8975A ($50 MAIL-IN 7/15~ 9/15/04 must also buy a qualifying wire...
My HP 5850 isn't printing
Good day.  The yellow teardrop-shaped icon flashes. When I press it, the flashing switches to the down arrow.  Meanwhile, the printer icon on my dock is nervous, jumping up and down like a hungry dog. Without a manual, I haven't been able to right what seems to be a simple problem. Thanks in advance.
  • 696 Answers
The teardrop shape is meant to signify ink, generally it means you are out of ink.
The manual you are looking for to resolve which one is located at:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=305980&
Hope this helps FixYa,
Chris
Posted on May 19, 2009
HP CP4025 produces no yellow image
Use the built-in print-quality-troubleshooting pages to help diagnose and solve print-quality problems. 1. Press the Home button. 2. Press the down arrow to highlight DIAGNOSTICS, and then press the OK button. 3. Press the down arrow to highlight PQ TROUBLESHOOTING, and then press the OK button to print the pages. The product returns to the Ready state after printing the print-quality-troubleshooting pages. Follow the instructions on the pages that print out.
This should get you started Isn't this printer still under warranty?
Aug 01, 2011 | HP Color LaserJet Enterprise CP4025dn ...
Teardrop shaped light flashing on hp 5650
Hello Sgaetjens,
The tear drop shape LED is called the print catridge LED indicator. If you do see this light flashing it means that there is an issue with one or both of the cartridges. This issue can occur for the following reasons:
  • One or both cartridges might be incompatible with the product.
  • One or both cartridges might be improperly inserted.
  • The borderless printing settings require adjustments.
For the first,two I suggest that you verify that it is indeed HP original cartridge and not just replacement ones that you can purchase anywhere. Remove and reseat the ink cartridges carefully. With regards to borderless printing, go to Control Panel and then Printers and open up your HP Printer and then check the properties and defaults. Normally it is under Printing Shortcuts where you could find Borderless Printing.
Jul 22, 2011 | HP DeskJet 5650 InkJet Printer
5850 hp. yellow teardrop light is blinking. it is not printing, worked fine yesterday
there is a problem with the ink cartridge either it is low/empty and needs to be replaced or perhaps there is something obstructing the cartridge contacts be it dust or a bit of ink but that is what i recommend checking
Jul 14, 2011 | Office Equipment & Supplies
How to find ink levels in hp932c printer
Print Cartridge Status The Print Cartridge Status Light flashes when one or both of your print cartridges are low on ink, improperly installed, or malfunctioning. It will also flash if you are trying to use the wrong print cartridge type. If the problem is low ink, the light will stop flashing when you open the top cover. For any other print cartridge-related problem, the Print Cartridge Status Light will continue to flash. To check the status of your print cartridges, open the printer's top cover. The yellow arrow on the print cartridge cradle aligns with one of five Print Cartridge Status icons.
Jan 08, 2011 | HP DeskJet 932c InkJet Printer
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Teardrop keeps flashing and won't print anything
Hi Good day.. The problem is on your ink level. To check your ink level please do the following.
1. Click "Start" then Setting
2. Click "Printer and Faxes"
3. right click your printer and then properties you should be in the printer box.
4. Click "Printing Preferences" and then you will see your actual ink level..
that why the teardrop is flashing, maybe your ink has ran out.. refill the ink or replace it with new one..
hope my solution help you.
Regards
JR
Oct 06, 2010 | Office Equipment & Supplies
My printer isn't printing, the teardrop button is flashing on and off and the down arrow button is flashing on and off. Does this just mean I am out of ink?
yes, you don't have ink. you can refill your cartridge by your own or you can go to an expert. take care that the colour number of your cartridge to be the same with the ink you buy.
Sep 04, 2010 | HP Deskjet D4260 Printer
Printer stopped printing; amber teardrop is flashing; no paper jam; cartridges should not be empty. Shouldn't there be a notice of low ink before it just stops printing? Or, the printed pages be faint? All...
The top access door on the printer might be open, or there might be something wrong with the print cartridge.
  1. Check to make sure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door opens, the print carriage moves so the yellow arrow on top of the print carriage points to a drawing of a cartridge inside the cover. Each drawing describes a symptom.
Jan 09, 2010 | HP DeskJet 5550 InkJet Printer
How do i get my flash to turn back on
Hi! To turn On the flash you just need to press the flash button on the top of the camera., Flash button is like a down arrow or lightning icon., make sure that the flash symbol is set to A -icon or eye- icon or may be a down arrow symbol., if you see on your LCD a circle icon with a down arrow it means your flash is off., Gudluck!
Oct 19, 2009 | Kodak EasyShare Z650 Digital Camera
Lost instructions for TE 109
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Sep 25, 2009 | Solar Ingraham 20 Program Electronic Timer...
HP 5850 COLOR INJET PRINTER C8975A ($50 MAIL-IN 7/15~ 9/15/04 must also buy a qualifying wire... Logo
140 people viewed this question
Seeker5211
Seeker5211
