Question about Saeco VIA Venezia
Water valve leaks on espresso machine
The water valve will not stop leaking when the knob is turned off
SOURCE: Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Posted on Jul 22, 2007
EsWorld
  • 1618 Answers
SOURCE: frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
SOURCE: Sirena espresso machine leaks water from under the
It's the hose from the steam boiler to the upper boiler. Part number 16000190 Silicone Tube 4,2X8,2. It is the same tubing as you would find on a fish tank with a red woven cover - I guess to prevent leaks. I cut out a short section that had developed a hole because it is not designed for the heat and pressure, but it shortly started to leak again. The tubing is not the correct kind for this purpose.
Now i am trying to find where to get a replacement tube without having to send it off someplace.
Posted on Sep 10, 2009
SOURCE: Unable to prime Sirena Espresso Machine
n regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Posted on Nov 29, 2009
SOURCE: The hot water steam knob on my Sirena espresso
I had the same problem. Here is how you fix it.
There are screws behind the water tank. Once these 4 screws are taken out, you can take off the top heat plate of the sirena. Then there are more screws holding down the outerlining from which the heat plate rests on. Take these screws out so that you can take out the outer lining. This will give you full access to the part you need to work on.
Once the machine is open you will need a small allen wrench to tighten the specific part that has come loose. It attached to the axle from which the knob is attached to. Its a metal part that resembles this picture at this link
http://www.rceasy.com/wp-content/uploads/2008/08/servo_arms.jpg
On this part there is a small screw that needs to be tightened so that it controls how far the knob can turn. When this part spins along with the axle, it will hit a stationary metal block that keeps it from turning too far. You will have to mess with the mechanics of it to figure out what I am talking about. Hope this helps and good luck!
Posted on Jan 26, 2010
Water leaks around the steamer
May be. If you get the machine upside down (switched off) you will find a hole near the steam knob which allows access to a screw. Turn this screw with a flat bladed screwdriver and the knob will come off. There is a gasket (washer) near the end of this know which is the seal. I don't know where you get the seal, but try finding a rubber seal in a gasket kit. This may be the problem.
Nov 25, 2013 | FrancisFrancis! X1 - Stainless Steel...
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
Tip
Ventilate error -
The following procedure works when you get the ventilate error:
The Ventilate sign can be due to one or more of the following reasons:
Cause 1- Water leaking from the inlet valve below the water tank. The hose from the inlet valve to the pump can be air locked. When using the hand pump, do not thrust its nozzle too deep
Cause 2- Blockage in the passage of water due to clogged passage anywhere between the pump and espresso delivery nozzle.
Cause 3- Pump is not working. Open steam/water outlet knob and hear the pump work. If you do not hear any noise from the pump, this may be the main cause.
Cause 4- Flow meter is faulty. This part is like the water meter for homes. It measures the flow of water and signals the electronic board. The malfunctioning flow meter will not send signals even when water is flowing through it.
Cause 5- Hose is disconnected and water is not flowing in the system.
Cause 6- O-rings at hose connection is leaking, reducing the water flow to be sensed by flow meter.
Cause 7- Boiler gasket is leaking. Reduces flow of water through the system.
Cause 9- Brew unit is blocked, blocking flow of water through the flow meter. This also causes pump to slow down and ultimately stop with muffled sound within 15 seconds.
Cause 10- Brew unit not connecting brew valve, preventing flow of water. Same sign under cause 9.
Cause 11- Steam is leaking. Registers reduced flow of water at the flow meter.
Cause 12- Solenoid valve is blocked or solenoid coil is bad. Same observation as cause 9.
Cause 13- Electronic Control board is bad. Though rare it can happen due to condensed water from leaking steam. When steam is leaking or boiler is leaking, machine should not be used any more to prevent steam shorting the Electronic board.
Some of the above causes can be checked and corrected before seeking technical help. Do not assume anything without physically checking each of the following:
1- Make sure the water tank is full. If the water tank has water level float, make sure the float is in its housing and it floats as water is filled in the tank. If the level float does not rise with the level of water, then replace the float.
2- Water is not leaking from below the tank. The inlet valve is good. If leakage is present, replace the gasket in the water inlet valve.
3- Prime the machine by opening the hot water knob for 20 seconds or pressing the hot water button. Hot water flow shows the boiler is not blocked with minerals and pump is good. The solenoid valve is good.
4- Water & steam flowing normal, check the brew group for blockage. Determine when was the last time brew group was cleaned. Clean the brew group as explained elsewhere on these pages. If the machine has pre-ground function, try making a fake espresso (without coffee). Make regular espresso in other models to make sure that water goes through brew group and espresso is dispensed.
4- If hot water does not flow because the pump is not activated, then pump is bad. Replace pump.
5- Pump starts to work but within few seconds its sound is muffled and finally stop. This indicates there is serious blockage in the water line or the boiler is clogged with mineral deposits. If water is leaking and seen on the counter top, the chances are that water is leaking from hose connections(replace O-rings) or the boiler is leaking from seams (replace boiler).
6- Prime the machine by opening steam outlet for 20 seconds. Steam flow shows that steam boiler / steam outlet is not blocked. If the steam does not flow, then steam boiler or steam passage is blocked. Replace steam boiler or steam valve
7- Check the solenoid valves to make sure that they open & close as the coil is energized. Solenoid valve is located between the pump and boiler. The pump is activated simultaneously as the solenoid valve when espresso selection button is pressed. Some models may have a solenoid valve near the steam valve. In these models, the solenoid valve is activated to allow passage for steam/hot water. If the valve is not functioning, the ventilate sign will appear.
7- Hear the pump work when priming the machine. Louder noise from the pump can be due to
** air-locked water hose, or
** water is not sucked from the tank or the pump is sucking air instead of water or
** the diaphragm inside the pump has lost flexibility and not developing pressure to push water forward
** the hydraulic system is blocked at one or more locations due to mineral sediment. Find the location and cause of the block and correct it.
** Clean the brew unit (see cleaning instructions) and make sure that
a- the ground coffee used is not powdery fine.
b- The dose of coffee grounds is not in excess specification
c- check if there is blockage. Find the cause and remove it.
8- If steam and hot water flow is normal, but the ventilate sign persists, then the flow meter or the electronic control board is bad. Replace flow meter or the control board, as necessary.
Try also the following:
  • Press hot water button once. Message on the screen will not change, this is normal.
  • Open the steam knob and allow the water to flow freely from steam wand into a cup. The screen should now read "Hot water,ventilate", you may need yo empty several cups of water before message changes. In some case it is necessary to refill the machine container without interrupting the operation.
  • As soon as the screen displays "hot water," turn the steam valve off .
  • If the machine warms up again, then problem is fixed.
on Jan 21, 2011 | Saeco Magic Comfort Plus Espresso Machine
Cant turn the steam knob
Replace the steam valve. It is not very hard to do and you can find a new valve with a Google search.
It is possible to attempt a repair but it is as hard to just replace the valve and repaired valve usually leak a bit.
Dec 28, 2012 | Rancilio Silvia Espresso Machine
The hot water spout is leaking constantly. The machine is running completely normal besides the leak.
Replace or rebuild the Valve (behind the knob).
Turn off the machine and release the steam pressure.Before you take it apart.
Oct 27, 2010 | La Marzocco Linea Series Group 3 Espresso...
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Saeco Magic Comfort Plus still producing steam in "off" position.
This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Saeco VIA Venezia Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
