Question about Myryad Audio Players & Recorders
Drawer to Myryad MC100 CD player is unstable & at times does not read CD's
4 Suggested Answers
  • 319 Answers
SOURCE: CD PLAYER NOT WORKING
laser lens broket..replace entire cd player by exchanging a $20 bill at a local merchant.
Posted on Feb 12, 2008
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Posted on Mar 04, 2008
  • 165 Answers
SOURCE: Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Posted on Jan 11, 2009
Technics sl mc410
The Optical Pickup(laser) has worn out. When you place a disc in the drawer, it has to load and read the TOC(table of contacts) if if can't read that, it assumes there is no CD in the drawer and stops or ejects.
Aug 28, 2014 | Technics Audio Players & Recorders
Myryad ma120 power amp,loud pop when switched off
Sounds like a Electrolytic capacitor has failed. Search backwards from the speaker connections inside the unit to the main PC board. Replace the first ones that you come accross that are linked with the speakers.
Dec 15, 2012 | Myryad Z Series Z160 Amplifier
Sony CD player CE-415 Drawer will not open.
This will require a professional, the more CD'S this unit can take the more complicated the loading bay will be. The most common problem is gear timing where the system is knocked out of sync and often locks down the device to prevent further damage. Sometimes the gears will strip jamming whole mechanism.
Mar 15, 2012 | Sony CDPM400CS 400-Disc MegaStorage(r) CD...
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
The playback drawer will not open, continues to flash "reading" until I press "play" and the it reads "clos ".
There should be a small hole on the playback drawer to allow a manual opening of the drawer. The player does not have to be on and preferably should be off when doing the manual eject. Take a paper clip, straighten out one leg, then push it into the hole about 1/4 inch until you hear a click and the drawer should open.
Feb 04, 2011 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
There is a disc jammed in my cd player and the tray sometimes opens and closes but wont bring the disc out
Hi
Thanks for using FixYa. Locate your CD player’s manual Eject button. It is usually a small hole located underneath the CD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the CD and see if there is a problem with it. Most CD player drawers get stuck when a CD is warped or the label is starting to peel. If the CD is warped, discard it. If the label is peeling, remove the label.
To open the CD player top to remove the cd/CD manually--
  • Unplug the CD player and take the outer casing of the CD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending CD tray finally comes to rest within the CD player. It’s the part that holds the CD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
 Before you remove the CD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
 Use the opportunity while you have the outer casing off to clean the lens of your CD player.
 Never work on an electrical device that's still plugged in.
 Opening a CD player may negate the warranty. Read your warranty carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | GPX KC318S CD Player
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Jan 11, 2009 | NAD C521 CD Player
I have a Numark HDCD1 that Drawer 2 will not read any CD I put in it. The CD plays in Drawer 1 when I put it in there. I also have already replaced the cable from Drawer 1 onto Drawer 2, and it still does...
I may be a little late, but for this problem you might have pirate cds burned off your computer in which the HDCD1 will not be able to read, could be the format.
Dec 15, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Mar 03, 2008 | Audio Players & Recorders
74 people viewed this question
Top Myryad Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Myryad Audio Player and Recorder Expert? Answer questions, earn points and help others
