Question about Audio Technica Audio-Technica ATM31A Professional Microphone
Information on how it works and how to use it
How can i get info on a 6 channel mixer/recorder audio- technica at-rmx64
SPAM ***** INTO THE SPEAKER UNTIL IT WORKS
Posted on May 19, 2009
Problem getting the sound from my pv6 mixer to my computer. i have windows 7. are they compatible or did i get ripped off?
Assuming you have the PV6 USB, the manual doesn't indicate compatibility with any Windows version beyond Vista. But, it's hard to imagine it not being compatible with Windows 7. What recording software are you using?
http://assets.peavey.com/literature/manuals/115024_160.pdf
Sep 09, 2014 | Peavey PV-6-USB 6 Channel Compact Mixer...
I have a tower computer kind of older . when i plug in the microphone to the back i.e. microphone port, nothing happens to signal it reads the microphone and when i try to use the microphone for fruity...
Assuming you are running windows XP you need to
1. right click the speaker in the lower right corner and select adjust audio properties.
2. Select the audio tab
3. Pull the drop down menu under sound recording and make sure it is selected to your audio driver device. Most are either soundmax, creative(for soundblaster and audigy standalone cards), realtek, or ASUS.
4. Next repeat step one but select open volume control
5. Go to options and then properties
6. Select the circle for recording and make sure your mic input is checked.
7. Close that window and recording mixers will pop up. Select the input you need by checking the box in the lower left corner of the mixer channel. Adjust the level and then use your recording program or sound recorder under Program files>accesories>communication>sound recorder.
Mar 08, 2011 | Philips Phillips...
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
I just got an audio-technica ATR6250 microphone, but I can't get it to work. It didn't come with any instructions. Might I be ignoring something simple that would get it working?
Always check the obvious first: Requires a fresh battery inserted correctly. Switch in On position
Two output cables: Left and Right. Try them separately. If combined into one cable it has to be done in a certain way or else it will short out the signal and you get nothing.
Try the shotgun mic with a recorder, mixer or camcorder and see if it works with any of them. If you are trying to use it with a camcorder there may be a menu setting to turn the mic jack on.
I
Dec 13, 2010 | Audio Technica ATR6250 Headphones
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
My mic keeps getting this popping noise wen i record, i have a pop filter an it's not a wind noise it's a crackling sound
Is it a condenser mic? Either your mic is bad or you need to add a compresser to your signal path...
Feb 09, 2010 | Audio Technica Audio-Technica AT2020...
Why can't I hear any sound when I record from my turntable conver
hi, you need first a pre amp phono or mixer before you patch into the computer to amplified signal in to your vinyl..
Jul 03, 2009 | Audio Technica AT-LP2D Turntable
How to connect mixer an amp to laptop?
How is everything hooked up?
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
Mar 20, 2009 | HP Pavilion dv9000z Notebook
Audio Technica Audio-Technica ATM31A Professional Microphone Logo
120 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
