Question about Microsoft Windows Vista Ultimate Edition
Everything frezzes i try to open a link from a page and the window frezzes complete for about 10 minutes or more, this happends also trying to print a page from the internet. i restarted the pc and still have the same problem, then opened the task manager to end these programs and it keep opening new windows of ending program (about 5) and last long time before close anything so the system doesnt want to respond when this hapends. I dont know what to do. when i restarted the pc it said i have 500 ram but i opened the system information and it says 4 g of ram which is what actually has. please help
  • luisamontero May 19, 2009
    Thank you so much
    Can you tell me what is restore the os with previous date?
    Thank you very much. You have a beautiful day too
    Master:
  • 118 Answers
THAT MEANS U R INFECTED WITH VIRUS WHICH USES THE CPU PROCESSOR UP TO 100 %
\& CHANGES THE SYSTEM PROPERTIES IF U DONT WANT TO FORMAT PLEASE RESTORE THE OS WITH PREVIOUS DATE WHEN UR COMPUTER IS WORKING PROPERLY
PLEASE WOTE FOR ME
Posted on May 19, 2009
  • HIT START BUTTON TYPE IN SEARCH "SYSTEM RESTORE" AT BOTTOM OF MENU THEN
    You will immediate see a screen where you can choose to roll back the system to the last restore point. You can select "Recommended restore", and just click next, or you can choose a different restore point.
    THEN SELECT THE DATE WHICH U WANT TO RESTORE THEN CLICK FINISH THEN OS MAKES CHANGES TO UR OS THEN IT RESTARTS IF UR FACING STILL THIS PROBLEM THEN CLICK SECOND OPTION IN SYSTEM RESTORE SELECT THE RESTORE POINT MANUALLY HAVE A NICE DAY
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
I have a laser jet 5 printer and two desktop units. I switch the cable cord when I need to print from one machine or the other. One computer prints fine the other sends everything to print que, this has...
Try to disconnect printer from computer, then restart that desktop computer. Also turn off and after ~10 seconds turn on your printer. Then try to to connect printer to computer.
Aug 16, 2011 | Office Equipment & Supplies
Printer won't print in black -- changed the cartridges. Nothing comes out on the page when I try to print.
the inkjet nozzle or printhead may be clog.
you will need to run the clean inkjet tool atleast 5-10 times to clear the inkjet nozzle.
  1. Make sure there is plain white paper loaded in the input tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
    HP Solution Center opens in a separate window.
  3. Click Settings (c01495176.gif ).
  4. Under Print Settings , click Printer Toolbox . The printer Toolbox opens in a new window.
  5. Click the Device Services tab.
  6. Click Clean the Printheads .
  7. Follow the on-screen prompts until you are satisfied with the quality of the output, and then click Done . When the cleaning is complete, the product prints a test page. Figure 13: Example test pagec01496479.gif
  8. Recycle or discard the test page.
Mar 06, 2011 | HP Photosmart C6380 All-In-One InkJet...
Lexmark 2470 only prints 1 page out of 10 pages!!!!
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 2400 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
May 09, 2009 | Office Equipment & Supplies
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
Canon MF6550
Try putting the cartridge in and sliding it to the right to make sure it is making a good connection. Try to make sure the cartridge door is shut firmly as to open the Laser shutter which allows the laser to write to the drum.
Apr 19, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
MFF6550 Printing nothing but white paper.
I unplugged my printer for 10 minutes and then plugged it back in. It went into an initialization mode and was fine after that.
Nov 15, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
On a go slow
try lowering the resolution quality
then make sure there is ink in the cartridges
hope this helps
Nov 07, 2007 | HP Photosmart 2575 All-In-One InkJet...
Printer acts like it's working then produces a blank page
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Jul 31, 2007 | Dell A920 InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
