Question about Toshiba 57HC85 57" Television
Projection tv i turn my tv on and it waits for about five seconds and it turns off there is a small light that is bliking infront of the tv it says timerstandby it blinks 8 times and then it stops for about four seconds and then it continues again
Toshiba 57HC85
Posted on Jan 18, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
Please give us some more details about your TV (brand, model etc)
Posted on Oct 25, 2007
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
I put a new lamp in last week. on the screen it ask me push enter so i did and the sentence went off the screen and the tv has worked good. now it is asking the same thing and i push enter and the...
reset the TV set, infront of your TV where the LED lights are there is a small reset botton that you can push with the tip of a pencil ot pen hold this botton down for 10-15 seconds then unplug the TV set and let it sit for about a 1 or 2 hours
then turn it back on it should work and if the TV still turns of after a few minutes you might have
a ballast issue sence you already replaced the lamp
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
It shutts off ramdomly the red lite blikes an have to what for green light to come on before it turns back on
Tv "LAMP" LED lite indication flashes or staying on?The tv projection lamp life is over.The projection lamp require changing.
Aug 06, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba 57HC85 57" Television Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
