Question about Vector 800 Watt Digital Power Inveter
Inverter fault light
I have a SUOER SAA-1200A power inverter and it's fault led is flashing
2 Suggested Answers
  • 608 Answers
SOURCE: vector 2500 watt inverter red led fault light no
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Posted on Mar 21, 2010
Sharp aquos model# lc-60e831u screen is not lite up and light flashing one long and one short
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 16, 2017 | Sharp Aquos Televison & Video
LED TV, DSE GE6880 TV flashes when power on; no picture, with audio. No backlights, has picture with flashlight test Have tested LEDs - all working Infrequently TV turns on and works no problem!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | Televison & Video
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
Sunna 3000TL inverter , red led light flashing ,
Unplug the inverter, and have the outlet tested. After being unplugged for a while, the inverter should reset when it is plugged into a grounded outlet.
Nov 26, 2013 | SMA Sunny Boy 6000US Inverter, 6000W,...
Blank screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 03, 2012 | Toshiba Satellite L505D-LS5010 Notebook
My laptop monitor is faded
May 19, 2012 | ASUS Computers & Internet
PRESARIO CQ57-356EA SCREEN IS BLANK BUT IS POWERING UP
Feb 08, 2012 | Compaq Computers & Internet
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Vector 800 Watt Digital Power Inveter Logo
26 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
