Lg 50pg3000 Black vertical stripe (6.5cm in width) running along the left hand side of the telly
SOURCE: Red Stripe, right side
Follow-up. I found the slip on which the LG tech wrote down the part number for the board to fix the vertical red stripe. I was mistaken in my previous post. It was not the Z-Drive board. The board you want is:
X DRIVE BOARD; Part 6871QRH043A
Type in the part number in a search engine and yuo will find multiple places to purchase. Ebay may be the cheapest. That's where I got another part which got my picture back. I did not buy this part myself because now that I have my picture back, I do not want to screw it up, so I live with the red stripe.
Posted on Jun 06, 2008
  • 586 Answers
SOURCE: Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Posted on Jun 27, 2009
  • 458 Answers
SOURCE: LG 50PG3000 SOUND BUT NO PICTURE
This sounds like a screen problem, possibly the internal connecting cable (LVDS) which connects from the main board to the screen may have become loose. If not a replacement screen would be required.
Posted on Jun 30, 2009
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
Posted on Sep 28, 2009
SOURCE: I just purchased a HP w2338h monitor. After only
There is an apparent design problem with this monitor. If you apply pressure to the edge of monitor the lines disappear, but when you remove the pressure the lines return. Had monitor three days when lines appeared. Currently waiting on replacement from HP. If same problem will return to store of purchase. HP must be aware of this problem I have seen several complaints posted on their website forum.
Posted on Nov 28, 2009
42" LG LCD has fuzzy section about 1/6 of screen on left side. If changes between multi colour and sometimes stripe the black part on the outside seems to pulse squeezing the section inwards
Check the LVDS cable from the main to tcon along with the flat ribbon cables going to the panel, if that doesn't help try a new tcon board
Dec 05, 2017 | LG Televison & Video
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
LG DT42PY10X Plasma left hand side is blank, sometimes random think multi-coloured lines run vertically. Right hand side perfect. Sound is OK. Any clues?
Hi:
You are going to have to replace the display driver Boards for the X Substain board. The two board are called hand insert buffer display drivers.
You can go to http://www.partstore.com
The part #'s are as follows:
LG Electronics/Zenith 6871QDH068B Y DRIVE TOP This is an alternative to LG Electronics/Zenith part 6871QDH068A LG Electronics/Zenith 6871QLH037A XRLT ASST X-LEFT
LG Electronics/Zenith 6871QDH069A Y DRIVE BOTTOM
Dec 24, 2009 | Televison & Video
Jun 29, 2009 | LG 50PG30 Plasma HDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
